Edited by stormintrooper, 20 May 2010 - 05:14 PM.
Caliper Pistons
Posted 20 May 2010 - 05:13 PM
Posted 20 May 2010 - 05:37 PM
Posted 20 May 2010 - 05:49 PM
what you need to do is get a caliper seal kit, minispares part number GRK5008. take the caliper off and remove the pistons by pressing the brake pedal, they should pop out easily. remove the old seals and replace with the new ones. clean up the pistons first before replacing the seals making sure all the dirt is out of the grooves the seals sit in. if there is any pitting on the pistons at all it is best to replace them aswell. get stainless steel ones as they will last longer
I Advise AS A Mechanic On Not Doing That
80% of the time the pistons will leak brake fluid And let air in making the brake pedal like a sponge
PERSONAL! I State Personal Id Do
1. Buy New Caliper
Or
2. Remove Caliper Off, use a piston pusher and push piston back, refit to car, pump pedal so piston moves out, and repeat, still it stops sticking,
(keep the caliper on the brake hose though)
I have done this on a Rover 200 and its still going well
But thats what id do Personal
Posted 20 May 2010 - 05:50 PM
Posted 20 May 2010 - 07:15 PM
Posted 20 May 2010 - 07:57 PM
outer wiper seals?
http://www.restorati...piston_leak.JPG
The Red Arrow
(that what can also happen when you buy them seal kits)
Posted 20 May 2010 - 09:18 PM
Posted 20 May 2010 - 09:44 PM
Posted 20 May 2010 - 10:00 PM
But It Fail On Braking Efficentce
Mine failed on it!! im running drums all round atm
Posted 20 May 2010 - 10:10 PM
Posted 20 May 2010 - 10:16 PM
but i will advise you change pads again if you do a caliper
better safe than sorry
Posted 21 May 2010 - 09:59 AM
Is this the general consensus?
Is it not worth fitting stainless steel pistons and new sills?
Will the caliper never be as good/safe as it was with the original pistons and seals?
Posted 01 June 2010 - 07:08 AM
If done carefully then you have no issues with safety.
You can rebuild them without splitting the caliper halves, however we just strip them out completely and send them off for plating.
I cannot comment on other makes and types of caliper other than the four common ones and our own calipers used on the Classic Mini.
