98mpi Bad Vibrations At 60>70 Mph
13 replies to this topic
#1 nicksuth
nicksuth
  • 1,631 posts
Posted 21 May 2010 - 03:30 PM
Bad vibrations from my 98MPi at between 60 and 70 mph but just had all wheels balanced - any ideas?
Wheel bearings feel okay, swivel joints okay, track rod ends fine, recently rebuilt front and back suspension with Minitastic Coil Springs (was okay for a few 100 miles and have checked nothing has worked loose), reasonably new Spax Gas Shocks all round and rebuilt Metro Turbo Vents (brand new) and 4 pots at front. Also, reconned radius arms and brackets fitted at same time as coil springs - car has run fine after all of these mods/repairs.
Any ideas?
#2 DeanP
DeanP
  • 499 posts
Posted 21 May 2010 - 03:56 PM
Next time study where you think the vibration is coming from. Is it in the floor, the steering..is it the rear? Did you do 70mph before these changes? If so and the vibration wasn't there it's definitely something you've done since.... Unfortunately a process of elimination.
#3 nicksuth
nicksuth
  • 1,631 posts
Posted 21 May 2010 - 04:11 PM
The symptom is vibration through the steering wheel, the root cause must be somewhere through the front of the car.
Just had a thought, I fitted a steering wheel dropper sometime ago, I wonder if the steering rack U bolts have worked loose? Job for the weekend!!
I'll apply my RCA skills :)
#4 DeanP
DeanP
  • 499 posts
Posted 21 May 2010 - 07:42 PM
One more to look at..... tyres.... it's rare but check to make sure both front tyres are seating correctly on the wheel. I had a vibration once and after jacking the car up and spinning both front wheels I noticed one of my tyres ran slightly eccentric to the rim. Doh.. :)
Edited by DeanP, 21 May 2010 - 07:42 PM.
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 21 May 2010 - 08:41 PM
I have the same even after tracking and balancing too: could it be deep dish alloys? (just what some people have told me)
#6 chrisholland1983
chrisholland1983
  • 1,359 posts
Posted 21 May 2010 - 09:32 PM
swop wheels back to front see if that stops it
#7 nicksuth
nicksuth
  • 1,631 posts
Posted 21 May 2010 - 09:49 PM
I've ruled that out because it has been okay in the past, only recently have the symptoms arisen :)
#8 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 22 May 2010 - 07:09 PM
Would be worth having wheel balance checked again - its not always perfoect, or a weight might have come unstuck...
#9 connor_cooper
connor_cooper
  • 164 posts
  • Local Club: no
Posted 03 June 2010 - 11:45 AM
I'm having the exact same problem, except it doesnt start vibrating until around 80, mines a 2001 cooper, let me know if you find out the problem, i wouldnt mind having a go at sorting at the weekend, if I work out what it is i'll let you know as well mate.
#10 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 03 June 2010 - 12:20 PM
I had my wheels balanced again yesterday and its gone. they also swapped teh wheels around a little as there were some problems with one not being "straight or true" (sorry lost in taranslation moment). I still get a bit of a shake but nothing compared to before.
The wheels now have lots of weights on them.
#11 datsun100a
datsun100a
  • 338 posts
  • Local Club: www.mini-chat.co.uk
Posted 03 June 2010 - 12:35 PM
check your pot joint play, could be the diff.
#12 nicksuth
nicksuth
  • 1,631 posts
Posted 22 June 2010 - 08:00 PM
Car been at the body shop but now have it back and tried a different set of wheels, what a difference !!! They're nearly new with new tyres and recently balanced so knew if it was still there then it was something a bit serious ? On closer check of the nsf wheel I see there is a flat on the rim (thanks to my son I guess) so set it up on a dummy shaft and spun it against a scribing block, ummm, buckled >:D now how did the tyre fitter think he had balance that :P ????
Anyway, problem solved.
#13 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 22 June 2010 - 08:05 PM
i had this alot when i worked at a tyre place
the wheels could be balenced wrong, hubs havn't been cleaned of rust and the wheel isnt sat properly
or the tyre is under infalted
they caused a few problems
#14 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 22 June 2010 - 08:16 PM
what are you tie bar bushes like?
