List Of Things To Buy For A Service?
Posted 21 May 2010 - 06:57 PM
What is a list of the things needed and where is the cheapest place to get them?
Posted 21 May 2010 - 07:00 PM
isnt it ...
oil (for a full oil change)
oil filter...
erm.....erm....
Posted 21 May 2010 - 07:01 PM
oil filter
sump washer
rotor arm
dissy cap
ht leads
spark plugs
air filter
(grease gun)
grease
spark plugs
support your local motor factor, if you use them enough ask for trade prices with a cheeky smile
Posted 21 May 2010 - 07:02 PM
oil filter
air filter
spark plugs
HT leads
distributor cap
rotor arm
points and condensor
a major service but what i'd do (i do this every year except P+C as mine is electronic ignition and i dont do air as i have a K+N)
unipart are good for mini bits
Posted 21 May 2010 - 07:03 PM
oh good...i wana know this one too....
isnt it ...
oil filter...
erm.....erm....
Ht Leads
New Spark Plugs
Rotor Arm
K&N filter cleaner
Posted 21 May 2010 - 07:05 PM
Posted 21 May 2010 - 07:09 PM
oh dont forget a new pine air freshener for the interior
Posted 21 May 2010 - 07:21 PM
Posted 21 May 2010 - 07:31 PM
oil (20/50)
oil filter
sump washer
rotor arm
dissy cap
ht leads
spark plugs
air filter
grease gun for the For The 8 suspension greasing points, front ball joints, top arm and rear radius arms, not greasing them regularly will result in having to change the ball joints and/or rear arm bearings and shaft more often than normal.
spark plugs
Points
condenser
Timing light for readjusting the timing after swapping the points and condenser.
Feeler gages for setting the point’s gap and for setting the tappet/valve clearances.
A rocker cover gasket if the old one is crusty, for when removing/refitting the rocker cover to adjust the above.
Edited by 1984mini25, 21 May 2010 - 07:35 PM.
Posted 21 May 2010 - 07:37 PM
aparently comma 20w50 and halfords classic 20w50, are good oils to use
I believe they are the same.
Posted 21 May 2010 - 07:43 PM
Posted 21 May 2010 - 07:49 PM
Alternatively if the dizzy cap is held in place with 2 crosshead screws, then you’ve got an electronic dizzy (no points) so just require a new rotor arm and cap for those.
Posted 21 May 2010 - 07:59 PM
Posted 25 May 2010 - 04:21 PM
heres one from minisport
http://www.minisport...o_KNNE2601.html
heres one from minispares
http://www.minispare...=...4487&title=
