Is It Legal To Make You Own Towbar?
9 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 22 May 2010 - 10:41 PM
hi is it legal to make your own towbar as i have a centre exhaust and dont want to swap it so what to make one to go round it then is it a good idea just to bolt it to the rear subframe?
#2 mini_adam
mini_adam
  • 198 posts
  • Local Club: fabmoc.co.uk
Posted 22 May 2010 - 11:04 PM
i think the tow bars that shops sell just bolt to the subby matey im gonna make my own at some point because i dont fancy payin em alot fot something i cud make for like 20quid
#3 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 22 May 2010 - 11:13 PM
I think you're OK to make your own and fit it a to a pre '96 mini. Anything after that needs a real towbar (for want of a better name0
#4 josh.evans
josh.evans
  • 1,439 posts
Posted 22 May 2010 - 11:16 PM
i was think of maybe using 40mmx40mm 4mm box section steel and can i bolt to the subframe and thats it or will i have to bolt it to the sheel also?
cheers
#5 HARBER07
HARBER07
  • 4,498 posts
Posted 22 May 2010 - 11:22 PM
The one that was in minimag bolted through the seat floor, but I can't see what being a good idea if its also bolted to the subby with rubber bushes?
#6 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Posted 22 May 2010 - 11:33 PM
40x40x4 box, what on earth are you towing??
Thats gonna be nearly 2" of ground clearance you've lost as well.
#7 josh.evans
josh.evans
  • 1,439 posts
Posted 22 May 2010 - 11:40 PM
right so may need smaller what would you reccomend as i will be towing a jet ski so........
#8 MRA
MRA
  • 7,607 posts
Posted 23 May 2010 - 07:03 AM
I think you will find there are legal implications..... there has been some discussion on this subject before, I would do a search if I was you...
#9 josh.evans
josh.evans
  • 1,439 posts
Posted 23 May 2010 - 08:09 AM
hi i have had a search and as long as the trailer with load is under 405 kg which it will be so should be all ok. also my car is 1991 so i can tow.
could someone reccomend the best places to bolt it to? would be a great help. also the size and thickness of the steel.
the only reason i asked this is that i dont really want to change my exhaust everytime as i have a motor bike exhaust coming out of the middle and there is a tow bar on ebay pre made but you cant use a centre exit and to be honist i will only have the tow bar on when i need it i will just take it off.
cheers
josh
#10 josh.evans
josh.evans
  • 1,439 posts
Posted 23 May 2010 - 06:28 PM
anyone else?
josh
