two amps to one sub?
minilover123
, Nov 16 2005 11:24 PM
9 replies to this topic
Posted 16 November 2005 - 11:24 PM
hi, i was wondering whether it is possible to wire two amps to one sub because i am buying a 1000rms sub and i was wondering if i could buy 2 500rms amps to power it?
Posted 16 November 2005 - 11:36 PM
yes i believe its possible but im not entirely sure how you would wire it, possibly by bridging the two amps together, ask where you get the wiring cables from. You will need heavy duty wire!
Posted 17 November 2005 - 02:00 AM
if you could afford a TRUE 1000w rms sub - then a 1000w rms amp would be pennies in comparison :wink:
What one are you looking at?
and by the way, unless it was a dual voice coil sub, and you used an osilscope to set the gains to be EXACTLY the same - dont expect the amps/sub to live very long
Posted 17 November 2005 - 01:14 PM
this sub:
http://www.alpine-eu...29507c2b21847f0
but a 1000 watt rms amp costs way more, i was thinking about bridging two of these to that one sub:
http://www.bassjunki...98&source=brand
Posted 17 November 2005 - 03:42 PM
I'd personally leave that amp well alone - as they dont say the RMS output, only "peak" output
and I stand by my statement - dont join 2 amps together, it'll only end in tears
Posted 21 November 2005 - 06:47 PM
You can indeed wire 2 amps to one sub
What's your budget for the amp(s) though? IMO there's not much point shelling out on a decent sub like the X and then going for cheap ampage...i.e. Sony :fear:
Have you got the sub already?
Posted 23 November 2005 - 12:54 PM
Just dont do it!!! AS Chair said it will end in tears!
Posted 23 November 2005 - 09:36 PM
yep agreed with CC, 2 amps to one sub is possible but not a very clever solution, best to get a decent 2channel or preferably mono.
If you are spending that kind of cash on a sub don't you need to be spending a few hundred on an amp, then when you've done this you'll need to make sure the battery and charging system are up to the job.
to be honest unless you've got about £500 to spend on an amp i wouldn't even think about it, just buy a sub you can afford to amp properly.
here's a few that would do the trick
Genesis Profile Sub Ultra
JBL BPX1100.1
JBL BPX1100.1
Posted 24 November 2005 - 03:36 PM
I wouldn't bridge 2 stereo amps i would just bridge cheap mono amps... surely the output of one amp could go into the input of the other? or is there limitations of what input you can have?
Posted 24 November 2005 - 06:21 PM
input ignores current, and only looks at the voltage (max is around 7v)
If you try to chuck it in any louder, you'll either just get massive distortion, or you'll fry something
the only way it's remotely possible, is to link them in parrallel, and hope that the amps are working at exactly the same frequency rates, otherwise they'll be fighting each other, and shorting each other out
If they do that, you may as well just connect the amp power leads together and short it out that way - saves having to destroy 2 amps
