Got myself a HIF38 to fit to my 998 but would like to see a picture if possible of how the throttle and choke cable connect.
Hif38 Fitted To 998
Iain L
, May 27 2010 06:42 PM
9 replies to this topic
Posted 27 May 2010 - 06:42 PM
Posted 28 May 2010 - 06:51 AM
Anybody please?
Posted 28 May 2010 - 07:11 AM
sorrt i do not have a pick
but i have fitted hif carbs to minis before as long as you have the heat shild plate with the clip for the chock cable and the hole for the throttel it should be fine.
are you experiencing problem fitting a HIF?
Posted 28 May 2010 - 07:12 AM
Posted 28 May 2010 - 07:19 AM
Thanks for reply. Well having small problem, mainly just wanted to see how the choke plate clip thingy worked.
Posted 28 May 2010 - 07:41 AM
the heat plat should be bolted between the monicold inlet and the exit pibnt of the carb. there will be a flat at the top with a rectangular slot in it that will have a clip in that holds the chock cable once the cable is clipped in then you can connect it to the chock assembly on the carb.
ahhhhh found a picture ! hope this helps? good job i brough my USB to work to day
HIF_carb.JPG 1.27MB
46 downloads
ryan
ryan
Posted 28 May 2010 - 08:33 AM
Perfect!
Many thanks mate
Many thanks mate
Posted 28 May 2010 - 08:54 AM
no worrys
Posted 28 May 2010 - 02:24 PM
Thanks mate, was helpful.
