Just after your views as to the worth of mini mini as Adrian Flux, after careful consideration of my request to up the agreed value, have come back with the same figure as last year - well worth the £10 charge!!!
Anyway here is the spec:
Restoration work – February 2007.
New front wings,
New A-panels
New front panel
Both door-skins and
Roof-skin replaced.
Full repaint including engine bay and boot are in BMW Chilli Red with Ford Panther Black Roof and wheel arches.
Exterior:
Group 5 wheel-arches and trim
Stainless Steel door mirrors
Stainless Steel bumpers
Mk1 Grill and moustache
4 spotlights on stainless steel brackets
Clear front and side indicator lenses
Halogen headlights
Revolution 6J x 12” wheels with 165/60/R12 tyres
Mk2 rear light clusters (no reverse)
Interior:
Corbeau bucket seats
Sparco 3 point harnesses
New door cards front and rear
New carpets throughout
Leather gear-stick and handbrake gaitors
Mountney 10” steering wheel with column drop bracket
New cream roof lining
Rear seat re-trimmed to match front seats
Custom speaker pods under dash rail
Custom dash with standard 3 clocks plus oil pressure/water temperature/voltmeter gauges (TIM)
Custom boot board kit incorporating 10” Subwoofer
Engine:
MG Metro 1275 over bored by +060 thou to 1330cc
AE 21523 pistons
Lightened & balanced crank, rods and flywheel assembly
Ported & polished 12G940 large valve head
Morspeed phase 3 camshaft and cam followers
Duplex Vernier timing gear
Fast road turbo clutch plate & orange diaphragm
Weber 40 DCOE matched to 5” stainless steel Maniflow inlet manifold
Stage 2 Maniflow Exhaust Manifold
Stainless Steel single box side exit Playmini exhaust system
Megajolt stand alone ignition ECU
Suspension / Brakes:
Adjustable Hi-Lo’s
Gaz adjustable shock absorbers
Metro Turbo 4 Pot callipers & vented discs
Minifin rear drum setup
Adjustable tie bars
Polyflex bushes all round
I priced all of the above up to cost around £4,000 without the body work cost or cost of the car originally.
So over to you guys - is it worth more than the £3,750 AF set it at, as they now want a valuation from a qualified automotive engineer and assessor!!
Wilson
Edited by Wilson1330, 27 May 2010 - 07:01 PM.
