Towing?
14 replies to this topic
#1 Big_Adam
Big_Adam
  • 7,435 posts
Posted 17 November 2005 - 12:30 AM
ok people,
rather large problem now and i'm going to have to push my car 1 or 2 maybe 3 miles if not.
how do i tow a mini if it has no tow ring on the front. i have to get my mini to the garage and it's at a friends house at the mo until i can get it there. i've tryed to make it go. i've tryed doing to point but now the battire is flat.
PLEASE FOR THE LOVE OF ALL THINGS MINI HELP!
that and i don't want to push my car all that way.....again
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 17 November 2005 - 12:33 AM
bump start it
#3 chairchild
chairchild
  • 606 posts
Posted 17 November 2005 - 02:32 AM
if it's an emergency, and you know the person towing you will be GENTLE -tie the tow-rope around one of the tie-rods
Done this before to one of mine with no ill-effects, after the towing eye kinda fell apart on me :nugget:
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 November 2005 - 06:55 AM
as above.... round the front of the tiebar, but would recomend a line to both to even out the pull.. remember you will have to use the brake in the car so give yourself a decent length and also mark the rope so other road users can see it..
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 17 November 2005 - 09:28 AM
the bar that round bit with the rubber bit that go's throught the sub-frame right??
#6 ian
ian
  • 676 posts
Posted 17 November 2005 - 10:01 AM
yes, they go from the bottom arm to the front of the subframe
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 17 November 2005 - 10:21 AM
ahhh, thatnk you all. i can tow my mini now. get it to the mechanic were he can fix it. i really should probly do a proper machincs corurce. i mean i can do some things but not other.
i changed the steering rack. well really thats about it on my mini.
anyway. thanks again people.
#8 ian
ian
  • 676 posts
Posted 17 November 2005 - 10:29 AM
you have already started the course........you bought a mini :D
take it easy when towing though, it wont take much to bend those Tie bars
#9 Big_Adam
Big_Adam
  • 7,435 posts
Posted 17 November 2005 - 12:55 PM
damn, ended up lashing it around the front of the subframe. my mum though the bars were too weedy to tow with. ah well. bent the body a bit but i don't mind it's all twiseted from were my brother tryed to tow it via the number plate. but now it's at the mechanics.
#10 chairchild
chairchild
  • 606 posts
Posted 17 November 2005 - 03:23 PM
lol, so she thought a bit of metal, the same thickness as the towrope you're towing with, wont be strong enough? :wink:
#11 Big_Adam
Big_Adam
  • 7,435 posts
Posted 17 November 2005 - 04:24 PM
hhmmmm, you make a good point there. ah well done now. the rope snapped right at the end as we were pulling into the mechanics. i nearly snapped it early on. but luckly didn't
#12 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 November 2005 - 04:59 PM
you can get towing eyes that fit through the front subframe tear drop mounts :smartass:
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 November 2005 - 05:11 PM
He said before that somehow he managed to snap the tow rings off his car!
#14 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 November 2005 - 05:47 PM
the towing rings are also the subframe frame mounts :smartass:
#15 Big_Adam
Big_Adam
  • 7,435 posts
Posted 17 November 2005 - 05:51 PM
i ddin't snap them off. my idiot of a brother did. the car was his before he gave it to me because he couldn't sell it.
he got some horrible saxo thing. it's bloody tiny inside.
