The Vacuum Hose On The Brake Servo
4 replies to this topic
#1 Neil7744
Neil7744
  • 250 posts
Posted 31 May 2010 - 04:35 PM
What does the vac pipe between the inlet manifold and brake servo do exactly?
#2 wassupcrew
wassupcrew
  • 502 posts
Posted 31 May 2010 - 04:40 PM
it transfers the vaccuum from the inlet manifod to the servo
#3 Ethel
  • 25,980 posts
Posted 31 May 2010 - 04:46 PM
It creates a vacuum >_<|
When you're on overrun, with the throttle shut, as you would be when braking; the suction created by the engine it transmitted to the servo via the pipe. The servo contains a big diaphragm, usually both sides of it are connected to the pipe. When you push the brake pedal you close a valve, isolating the 2 sides and open the rear side to atmospheric pressure the pressure difference that now exists across the diaphragm pushes it, and the master cylinder, harder than your foot alone.
#4 Neil7744
Neil7744
  • 250 posts
Posted 31 May 2010 - 04:47 PM
i gathered that...but why dows the brake servo need vacuum?
#5 Neil7744
Neil7744
  • 250 posts
Posted 31 May 2010 - 04:48 PM
ahh right, like an actuator.
