Lowered The Mini, Now Riding On Bumpstops
Posted 31 May 2010 - 06:38 PM
thanks, seb
Posted 31 May 2010 - 06:44 PM
Posted 31 May 2010 - 06:47 PM
Posted 31 May 2010 - 06:48 PM
Posted 31 May 2010 - 06:49 PM
Posted 31 May 2010 - 06:51 PM
yes, my first thougt was to cut them down, it is pretty low, theres about 3/4" between the top of the tyre and the arch. i think ill cut them down a little, thanks
Edited by sebmini, 31 May 2010 - 06:51 PM.
Posted 31 May 2010 - 06:54 PM
Posted 31 May 2010 - 06:57 PM
Posted 31 May 2010 - 06:59 PM
^^^ i dont want a praying mantus though ^^^
i had under 10mm between tyre and arch on mine and it wasn't on the bump stops at the back
Edited by sweetser, 31 May 2010 - 07:00 PM.
Posted 31 May 2010 - 07:09 PM
Posted 31 May 2010 - 08:27 PM
It quickly settled onto the bump stops without me realising and became horrible to drive and gave me back ache.
The bump stop spacers were removed as it is now running 10" wheels and this helped but it still banged down onto the bump stops far too often.
I have just given up and raised it back up, it doesnt look too bad, but drives so much better.
Posted 31 May 2010 - 08:40 PM
Posted 25 November 2010 - 06:58 PM
cheers
dean
Posted 25 November 2010 - 07:46 PM
* as my mini is really low lol
dean
Posted 25 November 2010 - 08:14 PM
and the front was just as low and wasnt on the bump stops...
That’s a simple one, there isn’t bumps stops on the rear of a mini with dry suspension
Running on the bumpstops is DANGEROUS ! You could fit Comp Hydro bump stops to the top arm, a much better proposition for cars this low.
Plus with the front of the car now sitting on the bump stops, the ONLY suspension you will have is any give in the tyres. So expect your tires to fall apart/wear quicker and good luck if you think it will handle especially in the wet, as it just simply won’t.
