Mini Automatic Dipstick
7 replies to this topic
#1 minizrock
minizrock
  • 16 posts
  • Local Club: mini REBELS!
Posted 31 May 2010 - 07:54 PM
I have a mini convertable project that has had all the body work completed by the previous owner. I have nearly completed the project but it came with no dipstick.
I think it was a mayfair but it has no identity so i may be wrong. It is a late car, must be 90's as the engine is an A+ without the bypass hose and it has the side repeaters, proper servo brakes and discs as standard on the front. It is a 998cc automatic.
The problem i have is not the lack of a dipstick as i can get one of those but i cannot see were the dipstick actually goes. I know this is a really silly post but i have had a good look around the engine and cannot see any form of hole. I am used to the early engine blocka and have never encountered an automatic before therefore i am seeking some help to the location of the dipstick. It is an issue because i obviously can't check the oil level. Is supposed to be just drained and filled with the correct amount on these?
I hope there is a current or past automatic owner out there that knows more about these engines then i do.
Any advice is welcome and no matter how obvious you may think it is please mention it to me it may just solve this problem.
#2 ShoutforJoy
ShoutforJoy
  • 738 posts
  • Local Club: TMF+, Automatic Mini Register
Posted 31 May 2010 - 08:06 PM
Hi, it's not a silly question - it took me a while to find it! I have a 1990 998cc auto - the dipstick is on the left of the engine (viewed from the front) underneath the coil.
Hope this helps.
#3 adam_93rio
adam_93rio
  • 3,271 posts
Posted 31 May 2010 - 08:15 PM
thanks for putting this up as a topic, i had no idea and i have an auto. (although ive barely ever looked at it sat awaiting resto)
although this makes me want to go work on it >_<
#4 MRA
MRA
  • 7,607 posts
Posted 31 May 2010 - 08:23 PM
Auto dipsticks are not the same as manual ones >_<
I have a couple left but they are not cheap, PM me if you want one.
#5 minizrock
minizrock
  • 16 posts
Posted 01 June 2010 - 07:46 PM
Thanks for the replys.
I will have a closer inspection.
#6 Tom Sanderson
Tom Sanderson
  • 708 posts
Posted 01 June 2010 - 07:54 PM
I think you can use a normal dipstick but you will have to cut it down and put new marks on it >_<
#7 adam_93rio
adam_93rio
  • 3,271 posts
Posted 01 June 2010 - 08:34 PM
Auto dipsticks are not the same as manual ones :angel:
just for reference how much are they? i know engine mounts are like £35 each :-
#8 minizrock
minizrock
  • 16 posts
Posted 07 June 2010 - 12:13 PM
after a closer look i have found the hole and the dipstick. the dipstick is plastic and had been snapped of flush with the top of the hole. i have managed to retrieve the dipstick. thanks for all your help.
