Engine Out Of Car Starting?
6 replies to this topic
#1 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 June 2010 - 02:36 PM
Hey folks.
Got a spare engine in my garage and I wouldn't mind starting it. Only for the reason of seeing if it will and trying some ideas out. Thing is, engine is free on the floor with nothing holding it down and starting a large lump of metal that contains explosions is a bad idea.
SO!
How should I go about starting an engine outside of a car WITHOUT it killing me or anyone else. Should I wrangle a spare front subframe and build up parts to hold the engine or should I make my own cradle, or am I wrong and it will be find to start?
Ta for any advice. I tried the search but "mini engine start" as a search tends to turn up a lot of stuff I don't need.
#2 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 04 June 2010 - 02:51 PM
It should be fine to start as is - they do it on scrap heap challenge all the time! :)
#3 Tom Sanderson
Tom Sanderson
  • 708 posts
Posted 04 June 2010 - 03:00 PM
Well its been done before...
#4 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 04 June 2010 - 03:04 PM
Just don't be so stupid and have your petrol tank/can inches away from a hot burning manifold.
Edited by GreaseMonkey, 04 June 2010 - 03:04 PM.
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 04 June 2010 - 03:42 PM
I just hooked up a long clear tube hanging from the garage roof attached to the carb inlet, enough petrol in the tube alone to start it
its easy enough
12v supply to a coil positive for starting for such a small time doesn't matter if ballast or non ballast.
wire from dizzy to coil negative.
then I used jump leads, negative just clamped on to block
positive I just used direct on the starter terminals.
and yes 14 seconds in that is a little trump :)
Edited by lrostoke, 04 June 2010 - 03:45 PM.
#6 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 June 2010 - 03:48 PM
Well I'll be, I always thought the engine would try and walk around killing itself or me.
I'll have to give it a try now.
Ta chaps.
#7 Azbornmini
Azbornmini
  • 93 posts
  • Local Club: Classic Minis of Arizona
Posted 05 June 2010 - 01:13 PM
This is not a bad idea. I did it as I didn't want to stuff a lump in that didn't have oil pressure, so we just put it on a table and fired it up!
Metro motor fist start in seven years
