Hi
I am restoring my 1960 mini, and it has the Old English White coloured central speedo housing. I removed to clean it up, and it looks like some kind, of mastic or putty was used to seal any gaps with the front bulkhead when fitted.
What is the best or most appropriate sealant to use when I replace it, bearing in mind I may have to remove it again in the future.
John
Central Speedo To Bulkhead...sealant?
mk=john
, Jun 04 2010 08:13 PM
4 replies to this topic
Posted 04 June 2010 - 08:13 PM
Posted 04 June 2010 - 08:23 PM
It's called body caulking, comes in strips like plasticene and should be available from a auto paint suppliers
Posted 05 June 2010 - 09:49 AM
what was its purpose though, cant it just be bolted to the bulhead?
Posted 05 June 2010 - 10:35 AM
my Mini with center speedo "had it" i took it off
its like gray blue tack
its just to stop water and dirty coming into the cab basicly
Posted 05 June 2010 - 09:43 PM
Hi
Well, i was at Somerford Mini today and they use `DumDum' sealant putty. I bought a tin of it and this is now what I will use. Its also used for things like sealing paned glass to window frames etc.
