Diff Locked Up....why
12 replies to this topic
#1 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 05 June 2010 - 10:08 PM
Right, i decided to assemble my Diff this evening, and upon tightening (not even at Torque setting) the diff has locked up! it is really stiff, and i cant seem to move it, saying that its not the best leverage.
All I have replaced is the Fibre washers, Roll Pin and put in an Uprated Diff Pin.
The other thing i have considered is that none of this has been lubricated with oil, as i intend to do that later.
As this has never happened before to me, i was wondering if anyone else has had some issues similar.
Alastair
#2 icklemini
icklemini
  • 2,982 posts
Posted 05 June 2010 - 10:36 PM
thinner fibre washers needed...
#3 liirge
liirge
  • 4,097 posts
Posted 05 June 2010 - 10:38 PM
ohhh, so its pinching against the thing that holds planet gears in place, if they're just fibre washers wont the first 1/2 a mile wear them in to the right size?
#4 Dave33
Dave33
  • 222 posts
Posted 05 June 2010 - 10:59 PM
Like said if its gone tight and not installed its the fibre washers causing this,unless there very worn use the old ones.
If its tight installed its because the diff side cover isnt shimmed correctly.
Dave
Edited by Dave33, 05 June 2010 - 11:04 PM.
#5 liirge
liirge
  • 4,097 posts
Posted 05 June 2010 - 11:28 PM
No, its not installed yet, so its got to be the fibre washers!
#6 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 06 June 2010 - 07:39 AM
The fibre washers are too thick as above.
if the old set are usable put them in, IIRC mini spares or MRA minis sell the correct thickness ones now as the rover washers were too thick.
#7 liirge
liirge
  • 4,097 posts
Posted 06 June 2010 - 11:37 AM
For reference my washers came from Minispares.
#8 GraemeC
GraemeC
  • 7,440 posts
Posted 07 June 2010 - 08:13 AM
Are these the ones you bought - read the description for the known problem with the genuine ones.
http://www.minispare...=...4233&title=
#9 liirge
liirge
  • 4,097 posts
Posted 07 June 2010 - 10:11 AM
Yeah they are the ones, i didn't really read the description as fibre washers are fibre washers...or so i thought!
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 07 June 2010 - 11:31 AM
What I meant was - did you get that exact part number, or the thicker ones with the very similar part number.
#11 liirge
liirge
  • 4,097 posts
Posted 07 June 2010 - 04:27 PM
I got the exact ones:
BTA101
#12 Dave33
Dave33
  • 222 posts
Posted 07 June 2010 - 04:33 PM
Are the originals worn out or are you just changing them cause its apart?
If theres no excess movement use the originals,otherwise measure the old ones and using a feeler gauge with them fitted work out what size you need allowing for some movement.
Dave
#13 the boy howard
the boy howard
  • 87 posts
Posted 07 June 2010 - 06:22 PM
When i fitted new washers my diff was mega stiff i couldnt work it out so i took it all apart and realised that there was a really thin ring off the old washers that had worn into a perfect circle just enough to make it stiff, scraped this off and fitted the new washers (from minispares) all perfect.
