Blue Smoke!
5 replies to this topic
#1 widg
widg
  • 41 posts
  • Local Club: Musketteers Mini Club
Posted 07 June 2010 - 06:26 AM
hi. i have a 1985 mini. 998cc. every time i use it blue smoke comes out the exhaust. if i go down hill with no throttle at te bottom when throttle is needed then a big puff of blue smoke comes out the exhaust and if im going up hill an change down gear and put my foot down then smoke comes out until i change gear back up can anyone help? :D
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 07 June 2010 - 06:51 AM
by the sounds of it the head requires some work on the valve stem seals and possibly valve guides
dave
#3 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 07 June 2010 - 07:45 AM
it could be a lot of things
Breather mesh rotted out allowing oil to flow into carb into engine
valve stem oil seals
valve guides
head gasket broke between oil way and cylinder
ones can could think of?
#4 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 07 June 2010 - 08:56 AM
could be the piston rings. do a compression test. or as stevee sugests valve stem oil seals. but if its a lot of smoke???? most likley Rings.
#5 Ethel
  • 26,027 posts
Posted 07 June 2010 - 10:06 AM
Rings tend to be worse under full throttle; valves on start up and part throttle.
#6 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 07 June 2010 - 10:09 AM
This is a classic test for valve stem oil seals, you go down a hill with little to no throttle, then when you put your foot down on the other side if you get a puff of smoke then your valves or seals need work doing to them.
