impove engine perfomance to 8000 rpm
Posted 18 November 2005 - 02:15 PM
know i use GT 1275 but.. not all the original part GT1275.i mix A+ & Aseries. only the block gt 1275
this year i upgrade my engine.only 7500 rpm can go full throltell. i can't exept this perfomance.i expect can get 8000 rpm. this i list part i use.
Head 1300 metro A+ (skim head)
rocker 1:3 ratio
block GT1275(skim Block)
+0.040 piston
metro A+ crank shaft
Kent cam 286 SP.M
duplex timing gear
3:44 gearbox ratio
standart flywheell 1.3
carburator HF6 use ramp pipe
all this part i use know in my car.
from what i use know,how bhp for this engine?
i hope all my freinds can give idea & suggestion.
thank you.
Posted 18 November 2005 - 02:26 PM
That cam doesn´t has its use in the 2000-7000 rpm range?! Around these figures at least.
Posted 18 November 2005 - 02:33 PM
Posted 18 November 2005 - 02:35 PM
some time i use for racing just for fun.my car can going to 7500 rpm full throtel, my father car use the same cam MD286ssp but can get 8000-8000rpm full throtell.Are you going to use it for racing?
what the probblem know?
because some time i want to challange my father car.
any idea to impove?
Posted 18 November 2005 - 02:36 PM
Or...
Putting a short stroke crank in.
Please remeber this is a 1950's pushrod design engine, not you modern Vtec/VVC Overhead cam unit.....
Race engines which do the 8000 upwards rpm, cost 10's of thousands to build
Posted 18 November 2005 - 02:43 PM
i use original rods GT1275 & +0.040 pistonYou wont get near 8k without, a Center mainstrap, a better cam (nearer 290-300 degree duration) and probably high cr... what sort of pistons/rods are you using ?
what u means?can u axplaine detail to me.
thank you.
Posted 18 November 2005 - 03:14 PM
strap
The CR is the compression ratio. You can achieve a higher CR by having metal skimmed off the head or by fitting different pistons.
A 286 cam like yours denotes the duration of the camshaft (how long the valves are in their open phase for) something like a 296 may be more suited for a higher revving engine, but you may lose some of the driveability at lower revs.
It might not be as easy to drive in traffic or at slower speeds. :wink:
Edited by mini mad me, 18 November 2005 - 03:15 PM.
Posted 18 November 2005 - 03:18 PM
To circumvent this, performance engines should have the maincap machined flat and a Steel bar is then used to provide additional support to the cap. In standard form the original two bolts holes are used, but in realy high spec engines then this is replaced with a whole new cap which utilises 4 bolts.
The duration of the cam is the time at which the valve is open, a 286 has a 280(ish) degree opening.
CR - Compression ratio... shoudl be looking at least 10:1 if not higher
Pistons, why type , ie are the cheap sh*te pistons or high performance ones..
The other thing is, if you run at 8k rpm... what sort of life do you want out of your engine... how often do you want to be rebuilding it.. ???
Posted 18 November 2005 - 03:49 PM
at malaysia got dyno test but it is very expensive for 1 time test.
