Engine 1293 C.c Problem
Posted 07 June 2010 - 05:47 PM
1293 MINI MOTOR C.C.
"Lighten CRANKSHAFT AND FLYWHEEL
Nitride-CRANKSHAFT
CAMSHAFT-C-AEA 731
-Lightening rods
Forged piston-ROUTE
-HEAD REDUCED, ENLARGED THE CHAMBERS, POLISHED bigger valves (the proper equipment)
-CHANGE STRAIGHT PINE CLOSE RELATIONSHIP
3.65-FINAL RATIO
PINION-PRIMARY LAYGEAR: 15, 19, 23, 25
"CHANGE IS, 17, 21, 26, 31
TECHNICAL PROBLEMS AND SYMPTOMS ARE:
-LACK OF FORCE IN THE OUTPUT (WHEN COMES TO backfiring and firecrackers DEJA 2500) and once COGE 2500 RPM AS A SHOOTING VA
WE HAVE TESTED WITH DIFFERENT CARBURETORS AND THEIR SYMPTOMS
DECO-Webb 45, 40 AND HIS DOUBLE DCOM
SAME WITH THAT TURNED THEIR SYMPTOMS
DELCO PLATINUM-MINI
METRO-DELCO PLATINUM
METRO-POWER ELECTRONIC
PLEASE HELP TO PUT A CAR POINT
THANK YOU
[email protected]
Posted 07 June 2010 - 05:51 PM
Posted 07 June 2010 - 06:11 PM
Posted 07 June 2010 - 06:18 PM
NOT IN MY COMING I've written
Posted 07 June 2010 - 06:26 PM
are you having problems putting engine together...?????
or are you having problems trying to start engine.....?????
or are you having trouble running......????
Posted 07 June 2010 - 06:50 PM
Posted 07 June 2010 - 06:51 PM
The OP has out of desperation tried to get a positive result to their query, laughing is not the way forward
Posted 07 June 2010 - 06:54 PM
but in a mini I have a problem with the engine and after installing it all When it has to start the car backfires and will not accelerate
thanks for everything
Posted 07 June 2010 - 06:59 PM
hope you find this helpfull.
Posted 07 June 2010 - 07:19 PM
Try the following
Ignition timing -- Regulación de encendido
Cam timing -- sincronización del árbol de levas
valve to rocker clearance --- separación de la válvula
HT leads in correct order -- plomos de la alta tensión
Posted 07 June 2010 - 07:30 PM
Hola,
Try the following
Edited by bmcecosse, 07 June 2010 - 07:31 PM.
