Edited by twackler, 08 June 2010 - 12:31 PM.
Hs4 Throttle Return.
Posted 08 June 2010 - 12:22 PM
Posted 08 June 2010 - 12:30 PM
Posted 08 June 2010 - 01:10 PM
Posted 08 June 2010 - 01:25 PM
Posted 08 June 2010 - 02:08 PM
Posted 08 June 2010 - 02:58 PM
So I cut the throttle spring in half and make a new hook on the end. Problem solved.
Posted 08 June 2010 - 03:13 PM
Posted 08 June 2010 - 04:00 PM
It turned out to be the spindle had a lot of play in it and the disc would catch as the throttle closed.
I had a HIF carb at the time and the local garage (a mini fanatic as well) told me to ditch the HS4 in favour of the HIF.
He fitted it and set it up.
The car has run fine since.
Only thing he recommended was to keep a close eye on the top engine steady rubbers (poly in my case) as when they wear, the carb may touch the bulkhead as it is closer than the HS4 setup.
Posted 08 June 2010 - 07:40 PM
So i'm gonna take the carb off and have a fiddle, may modify the spring whilst i'm at it.
One thing that did make me wonder,when i sprayed wd40 on the ends of the spindle there was a change in the engine note as if the wd40 had found it's way inside the carb is that normal ?
Edited by twackler, 08 June 2010 - 07:42 PM.
Posted 08 June 2010 - 07:56 PM
Posted 08 June 2010 - 08:06 PM
Has anyone got a tip for threading the choke cable back through it's little hole on the cam lever mine is a bit frayed and i haven't got enough play to be able to cut it.
Edited by twackler, 08 June 2010 - 08:13 PM.
Posted 08 June 2010 - 09:58 PM
Posted 09 June 2010 - 11:05 AM
Posted 25 October 2010 - 11:20 AM
I've just taken my carb off and the hole in the disc is below the spindle shaft !!!!what would the consequences be ?Have you put the throttle disk (if touched) round the right way, it chamfered so will only close completely if round the right way, the little hole in the disk should be above the shaft not below.
Edited by twackler, 25 October 2010 - 11:21 AM.
