i have a 1986 austin mini mayfair 998cc
basicaly i was wondering how hard it would be to rewire the whole car. for some strange reason when i put my lights on the starter motor starts kicking back in. and when i start the car the lights come on even tho the switch is turned off.
so basically would i be able to rewire the car myself?
cheers
sean
Re Wiring
sheepy89
, Jun 09 2010 12:35 PM
8 replies to this topic
Posted 09 June 2010 - 12:35 PM
Posted 09 June 2010 - 12:44 PM
You have a short between the lights and starter feed. but can you let me know is it on side lights or headlights or main beam. it is most likely a quick fix. when you switch just the side lights on does that cause you fault or is it when you put the headlights on (switch at second click.) try this with the full beam stalk switch at off.
Posted 09 June 2010 - 12:46 PM
its when i put the main beams on (2nd click) then if i turn them off and back on again it stops
Posted 09 June 2010 - 12:57 PM
Ok have you moved any of the connectors on the fuse box? if not then its defo a wiring short in the front loom. check the cables as they come off the starter motor and trace them back to the relay on the inner wing. if anything looks burnt or sliced through or insulation rubbed away that could be your problem. if all looks ok then do the same for the wires which come from the head light connectors behind the front panel. they should be close to the horn. there should be a blue/white a red/blue and a black. its the blue white thats for the headlights and red/blue for the side lights so have a good look at the blue white.
Posted 09 June 2010 - 12:59 PM
Im off to collect my mini now to double check all that im telling you so we can get this fixed for you. back in about 1 hour.
Posted 09 June 2010 - 01:00 PM
cheers ill go have a look now
Posted 09 June 2010 - 01:40 PM
just had a look and i cant see any splits or bare wires. the relay switch was looking a bit knackerd so i changed that and it seems to have worked. cheers for your help. if it happens again ill post back up
cheers sean
cheers sean
Posted 09 June 2010 - 01:41 PM
cheers sean
cheers sean
Posted 09 June 2010 - 08:20 PM
A new harness would be your cheapest and easiest route..... unless you are a wiring harness design or manufacturing engineer / technician
