12g295 Fitted To A 998 Sprite
Posted 09 June 2010 - 08:56 PM
I plan to fit it to my Mini Sprite 998. I understand this head can give about 6bhp difference to the stock head. Fitted to my sprite is a stage 1 kit, along with the 12g295 cooper head and a good compression ratio how much Bhp are we looking at?
Matthew.
Posted 09 June 2010 - 10:16 PM
Hi all, recieved a head which I purchased ebay a couple of weeks ago, I have cleaned it up and would like to get it restored at the Mini and metro centre.
Matthew.
Hi Matthew
Ive fitted this type of head to a couple my mini's and is on my current one. Ive fitted twin carbs to mine aswell. Dont know the exact power increase (Needs rolling road)but it does improve the power and torque if set up right.You need to get the head skimmed right to give you the correct comp ratio.
Regards
Matt
Posted 09 June 2010 - 10:57 PM
Posted 09 June 2010 - 11:40 PM
Ah good, I just have a modded carb to increase air flow. I am planning to have 80 though taken off the head.
Posted 10 June 2010 - 07:19 AM
I just built a 998 using the same head casting (mine came off a wolesley 1100) the motor was standard bore just honed, 649 cam, lcb extractors and a hif38 on metro inlet with pod filter, before the engine swap the car would be in 3rd or even 2nd to get up hills and top speed it would do was 110km/h, after the swap and running in period the car would accelerate up the same hills in top gear and would still be accelerating pretty well at 120 km/h.Hi all, recieved a head which I purchased ebay a couple of weeks ago, I have cleaned it up and would like to get it restored at the Mini and metro centre.
Matthew.
I did have to get 100 thou taken off the head though in order to get around 9-1 compression ratio (chambers went from I think 26cc down to 21cc)
Posted 10 June 2010 - 07:48 PM
As the 295 will be an old head you don't know if it's been machined before, but take care not to skim too much off or you can break into the oil gallery. Get a depth vernier and measure the depth of the oil way hole inside the head, then measure the total thickness of the head. The difference, less 0.050", is the absolute maximum you should skim as if you do skim that much you'll have only 0.050" left before you break through. I would rather use 0.060" as a minimum, but 0.050" is a figure I've seen quoted elsewhere.
Posted 10 June 2010 - 09:38 PM
Posted 16 June 2010 - 10:30 PM
12g295
HS2 Twin Cabs
Stage 1 Kit
Sounds good to me
