Hissing Noice When On The Throttle
10 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 June 2010 - 10:19 PM
96 spi
in sum when on the throttle i hear a hissing type sound, and it stops when i take my foot off the pedal.
hard to say where its coming from but could it be the alternator / fab belt needing tightened?
cheers
#2 foxfan
foxfan
  • 269 posts
  • Local Club: No
Posted 11 June 2010 - 10:56 PM
Is your air filter sitting correctly on the carb ? I didnt put mine back on properly once and it made a sucking noise when I accelerated.Sounded a bit like a hissing noise!
#3 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 June 2010 - 11:02 PM
as above 96 spi - no carb, cheers though
#4 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Nottsaboutminis
Posted 11 June 2010 - 11:19 PM
sounds like an air leak past the filter on the throttle body.
very similar to an air leak past the filter on a carb. ;D
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 11 June 2010 - 11:24 PM
doesnt quite sound like its from that area. But will def check it!!!
Its teh kind of sound which is hard to tell where its from , if you get me.
I would say its coming from the left hand side, (thats where i sit, the car is LHD), but i couldnt say if it was from the rear or fornt.
all a bit of a puzzle and no other symptoms apart from the hissing (esk) sound.
#6 pauly_boi
pauly_boi
  • 213 posts
Posted 11 June 2010 - 11:27 PM
you checked all the pipes are correct and tightened. might be worth opening the engine bay and getting a mate to rev it whilst you look and listen to see where its coming from
#7 delboyeire
delboyeire
  • 65 posts
Posted 12 June 2010 - 12:20 AM
could be a vacuum?
#8 electricjim
electricjim
  • 237 posts
  • Local Club: WSMOC
Posted 12 June 2010 - 11:56 AM
vacuum pipe from carb or vacuum unit
Edited by electricjim, 12 June 2010 - 11:56 AM.
#9 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 12 June 2010 - 12:41 PM
as he said no carb , i would take a guess at an air leak probably vacuum or air filter
#10 The_Mistro
The_Mistro
    Farmer Barley Mow
  • 2,369 posts
Posted 12 June 2010 - 12:46 PM
is it a standard air filter? mine makes a hissing noise since i put my pipercross induction kit on!
#11 turbominicooper
turbominicooper
  • 295 posts
Posted 12 June 2010 - 12:53 PM
agree, if its a perfomace one they all make that sound wether its carb or injected. My mate loves that sound (think he likes to imagine hes a got a turbo winding up lol)
