better throttle response?
8 replies to this topic
#1 beemerduck
beemerduck
  • 428 posts
Posted 19 November 2005 - 03:20 PM
Hi... I wonder if someone can help me?
my standard 998 (bar a k&n) runs fine but the throttle response isn't up to much.
But when I pull the choke out a little the throttle response is superb, although, obviously tick over is a bit fast... this happens when the engine is cold or warm.
This may be typical of the 998 engine, I don't know, as its the first 998 i've had.
But theres gotta be a better way to have a better acceleration, other than using the choke????
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 November 2005 - 03:31 PM
When you pull the choke out a little, not only are you increasing the idle, but also the mixture, it sounds like you are running lean..
As you say your car is fairly std, it's probably running an HS4, therefore the JET adjustment is on the bottom of the carb, give the lower of the larger nuts half a turn clockwise ( looking from the top of the carb ) this will richen the std mixture.
#3 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
I would suggest you get a tune up. Pulling out the choke is essentially making the car richer, if it runs better like this when it is warm, then maybe it is running a little lean?
You don't want to be running on the choke all the time!
#4 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
LOL, someone always beats me to it! :cry:
#5 beemerduck
beemerduck
  • 428 posts
Posted 19 November 2005 - 03:44 PM
thanks guys... I thought that might be the problem.
I'll get it tuned. As I havent touched it since I added the air filter.
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 November 2005 - 03:46 PM
it's also getting colder which increases the air in the air/fuel mix.. :cheese:
MMM :tongue:
#7 beemerduck
beemerduck
  • 428 posts
Posted 19 November 2005 - 03:48 PM
so basically the mixture needs to be set twice a year? for warm and cold climates?
#8 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 November 2005 - 03:49 PM
MMM :tongue:
One day I'll beat ya to it! :fear:
At least I was right again, lol :cry:
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 November 2005 - 07:15 PM
No, you don't need to get your car retuned for winter or summer. You do however have to get it retuned when you fit a K&N as the new filter flows a lot more air than standard and the carb isn't setup for it. Funnily enough if you don't get the thing tuned for the K&N it will run lean, sound familiar? You need to sort this soon, as we go into the winter it will get leaner and very lean engines blow holes in their pistons.
