Hi, has anyone sprayed their headliner because ive been told fitting a new one is a right hassle. if you have sprayed it what did you use, what was the finish like and is it worth it?
Thanks Ross
Headliner
rossul.burn
, Jun 13 2010 09:45 AM
8 replies to this topic
Posted 13 June 2010 - 09:45 AM
Posted 13 June 2010 - 10:34 AM
Here was my headliner. The previous owner had stuck some fur material to it and one hot day the glue melted and it all just fell off. I was left with a tatty old headliner full of glue:
So I rubbed it all down with a rag with thinners on it to remove all the glue, it ended up taking the colour out of it to, but left a good surface for paint:
I then painted it with black emulsion and a little foam roller. It took a couple of good coats to into the textured surface but it looked great afterwards:
Posted 13 June 2010 - 10:52 AM
Bloody hell thats a really good finish on that! when did you do it and does it still look that good? also has the paint not cracked?
Posted 13 June 2010 - 11:08 AM
In the 80's, I redid my headliner with shoe dye.
I repainted car blue, i did the headliner pale blue because it was a bit crappy.
Came up well but sadly any pictures have long gone.
Posted 13 June 2010 - 11:16 AM
Many years ago I painted he roofliner white which was that had turned nicotine brown due to previous owners. Although being dubious I painted it with a pot of white just using a brush and was very pleased with the results, it far outlasted the car and got rid of the ashtray smell! Afraid I can't remember the name of the paint but it was proper paint for the job.
Posted 13 June 2010 - 11:19 AM
so its possible but im just worried of the paint cracking and looking worse than it would have done before painting
Posted 13 June 2010 - 12:30 PM
Mine didn't crack at all and it was done 2 years ago now. You can buy vinyl paint in spray cans but it'll cost you more money that way.
Mine was just some decent quality johnsons black emulsion
Posted 13 June 2010 - 12:35 PM
Done, many with vinyl spray, works a treat. Just make sure the headlining is clean first and then spray away.
Posted 13 June 2010 - 09:41 PM
is there anywhere that does white vinyl spray?
