Lower Suspension Ball Joint
Posted 14 June 2010 - 08:11 PM
My mini failed it's mot a few days ago due to excessive play in the lower suspension ball joint.
I've bought a ball joint kit. How do i go about fixing it?
Sam
Posted 14 June 2010 - 08:14 PM
Edited by samsernie, 14 June 2010 - 08:14 PM.
Posted 14 June 2010 - 08:36 PM
Next lap in the new ball joint by temp building up the joint with a small amount of valve grinding paste but just hand tight, then use a battery drill on slow speed to spin the joint. tighten a bit more and spin again.
now take everything apart and clean very thoroughly. (really clean) you need to get rid of all the grinding paste.
now reassemble the joint with some of the shims in place an tighten it up.
Its trial and error at this stage im affraid as you dont know which shims to use, some old some new. But when its correctly shimmed you should still be able to move the joint (just), with the big nut done up tight.
By move the joint I mean with a gentle tap with a rubber mallet or with a ring spanner over the shaft. it should be to thight to move by hand. unless you are very strong.
When you are done close the tabs on the big washer and refit the hub to the car.
All the bits you need will be in the kit. new tab washer shims etc.
Good luck with this as I can honestly say this is my least fav job EVER!!!
Posted 14 June 2010 - 09:13 PM
I'll see if i can follow your instructions
Posted 14 June 2010 - 09:16 PM
Posted 15 June 2010 - 01:10 AM
Always remember to knock the locking tab over them well once they're done!
Posted 14 May 2012 - 10:35 AM
I only have the problem in one side (off-side ball joint) is it best to replace both sides.?
Posted 14 May 2012 - 11:27 AM
You could remove the brake caliper and detach all 3 ball joints so you can turn the hub upside down, on the car, and avoid splitting the driveshaft to remove the hub. Be careful not to pull the pot joint to pieces though.
Bottom ball joints are spring loaded, so do have (vertical) play; I'll give the tester the benefit of the doubt if he didn't fail both sides.
Posted 14 May 2012 - 06:12 PM
As Ethel says, the lower joint does have a spring, which stops it rattling, as it sometimes becomes unloaded vertically, unlike the top joint, which is always under load. It is easiest to set up the shimming without the spring, and put it in last, because it is hard to feel for play with it in.
Posted 11 January 2015 - 11:10 AM
Does anyone have this ball joint video I can view please? when I click the link I just get told its private
Posted 11 January 2015 - 11:33 AM
quite old that so no idea if its still available
the manual describes it quite well though, apart from the lapping bit, do you have any manuals?
my advice would be to start with top quality parts though; I have some decent quality ones than I'm going to be fitting soon and some not so good and the not so good ones aren't hardened, so they are going to wear by the time you get to the bottom of the road, so I wont be using them.
Also I would echo tigers advice above; the manual states between no nip and .003" end float, so not tight
Posted 14 January 2015 - 10:14 AM
Thank you, got some from Wood and Pickett so will see how I get on
