I was wondering if its possible to create a heat shield to go behind the exhaust manifold to stop heat getting to the fuel pipe, at the moment its quite close and the pipe is touching the bulkhead, so what can i use to stop heat from getting to the pipe and stopping the fuel heating up too much without re-routing the pipe.
cheers
Jackman
Heat Shield
Jackman
, Nov 20 2005 07:34 PM
6 replies to this topic
Posted 20 November 2005 - 07:34 PM
Posted 20 November 2005 - 07:57 PM
there's close to zero airflow behind the engine, so your best bet would be to put a small fan down there to circulate the air
Just putting a slab of metal there is kinda like putting a similar setup in an oven, it's gonna get hot no matter what!
Posted 20 November 2005 - 08:05 PM
If there's zero airflow behind the engine, how does air get to cone air filters?
Posted 20 November 2005 - 09:16 PM
Yeah there is air flow at the back of the engine. Otherwise no air will go to the carb :S
Posted 20 November 2005 - 10:43 PM
The engine sucks the air in! It doesn't get blown in :grin: :grin:
As long as all the connects are secure and the fuel line is in good condition i wouldn't worry, the extra heat will only help with combustion.
Posted 21 November 2005 - 11:59 AM
So i guess i cant do anything then apart from re-route it.
Posted 21 November 2005 - 02:58 PM
got it in one :wink:
