how and what would i need to fit a rev counter to a sprite preferably in a 3 dial style dash not mounted somewhere else
thanks Ross
How To Fit Rev Counter/ Tachometer
rossul.burn
, Jun 18 2010 11:09 AM
2 replies to this topic
Posted 18 June 2010 - 11:09 AM
Posted 18 June 2010 - 11:22 AM
Pretty simple - if you buy a 3-dial set of clocks (make sure theyre the correct type for your car), you simply just plug the green/yellow(?) wire and the black/white wire into the back of the clocks.
The wires should already be in place in the loom and should be just hanging loose behind your current clocks.
This question has come up a lot, so if you do a search you should find more answers if you need them
Chris
Chris
Posted 18 June 2010 - 11:51 AM
thanks i tried searching but not luck, but your answer sums it up. Thanks
