Lambo Sensor
Posted 19 June 2010 - 02:28 PM
Have recently fitted a 3 branch to m Mpi, and relocated my lambo at the bottom of the manifold just before the Y piece, but know the car is over heating very badly? sometimes after only 15mins, fan and pump are fine??
Posted 19 June 2010 - 02:29 PM
lamda sensorHi
Posted 19 June 2010 - 02:38 PM
lamda sensorHi
fail it's lambda
Posted 20 June 2010 - 05:03 PM
You say you have fitted the sensor before the y piece? If this is correct you will need to relocate it to after the y piece so that it is exposed to the exaust gases from all of your cylinders so the ECU can determine the correct A/F ratio. Your A/F ratio could be far enough out to cause overheating.
Maybe you could post up some pictures so we can all see exactly what's going on?
Posted 21 June 2010 - 08:46 AM
Posted 21 June 2010 - 10:48 AM
Sounds like you might have an airlock in the watr pipes or altenatily a bad rad cap
I would suggest flushing all the coolent out the car. run a low pressure hose throu the system untill all the water passes out clear.
Refit all hoses and fill the car with water and coolent suitable for summer use. Squeeze the top rad hose to circulate it around the system. Top up again to the mark. LEAVE THE EXPANSION CAP OFF
Switch the heater to speed 2 and full heat. Start the car and allow it to warm up. keep an eye on the water levels. The gauge should move up to half way in about 10 minutes.
Check water levels and top up if required
Fit a new pressure cap on the expansion tank. These can be obtained from halfords. Ask for a meto expansion tank cap... exactly the same. if they ask what year, say 88 onwards.
HTH
Mike
