Oil sump
Posted 21 November 2005 - 11:03 AM
thanks
Posted 21 November 2005 - 11:47 AM
If it looks like this then you're close to new case, this has not only lost the thread but the aluminum has started to corrode and break up, I'm going to try an experiment with this using a realy BIG sump plug but esentially Id be looking to scrap the case...
Is the engine in the car still, as with most things, if they have over tightened the sump, then if they have done any other mechanical work, then they are likely to be over tightened too... and it does not take much to strip the thread out of aluminum...
Posted 21 November 2005 - 12:23 PM
Posted 21 November 2005 - 12:26 PM
Posted 21 November 2005 - 12:59 PM
obviously you would have to remove and refit the box yourself.
Posted 21 November 2005 - 01:25 PM
You could do the same on a Mini sump, but you REALLY would need to modify the nylon plug to accept the drain magnet. What I would try instead is chasing the hole with the HeliCoil tap again and trying another HeliCoil. Make sure the ends of the wire insert are below the sealing face for the plug and seated properly in the threads and you should be OK. I've only seen HeliCoils back out under two circumstances 1) Thread sealant/locker (which shouldn't be used) was placed on the fastener (plug), or 2) the insert was installed in a way that the wire doesn't lay properly in the tapped hole causing it to bind on or bite into the fastener (plug).
If you, a mechanic, or a previous owner used a sealant or thread locker on your drain plug, that's likely why the HeliCoil backed out. You can switch to a nylon/plastic 14mm drain plug washer or a steel sealing washer with an o-ring bonded to its bore as a sealing washer instead of the stock Mini one. These require MUCH less torque to seat which will protect the sump thread.
Posted 21 November 2005 - 01:44 PM
It is one of the most annoying thing to happen tho!! and i only just got it!!
Posted 21 November 2005 - 01:47 PM
Posted 21 November 2005 - 02:26 PM
Posted 21 November 2005 - 02:43 PM
Posted 21 November 2005 - 02:52 PM
Posted 21 November 2005 - 03:38 PM
If a Helicoil is properly fitted then it shouldn't come out on it's own for a long long time (many duty cycles).
The traditional way to repair this thread after the helicoil has failed is to use a tapered sump plug (available from all Mini specialists). I have a problem with this however as the tapered thread is pretty much going to do more damage every time you fit or remove it and as such I don't see it as a solution. It only prolongs the life of the gearbox casing by an extra few oil changes rather than repairing the damage. I think this insert idea is a much better plan all round.
Posted 21 November 2005 - 03:42 PM
