Water Heated Inlet
8 replies to this topic
#1 Luipolly
Luipolly
  • 28 posts
Posted 23 June 2010 - 09:34 PM
how do you connect up a water headed inlet manifold?
#2 duds_12
duds_12
  • 117 posts
Posted 23 June 2010 - 09:43 PM
this is mine hope it helps
#3 duds_12
duds_12
  • 117 posts
Posted 23 June 2010 - 09:44 PM
minus the kinks
#4 bmcecosse
bmcecosse
  • 9,699 posts
Posted 23 June 2010 - 09:45 PM
In summer - definitely don't bother! You 'may' want to heat it in winter - in which case put it in the return loop from the heater. But consider - twin carbs don't have heated inlets - so why should the single need heating ??
Edited by bmcecosse, 23 June 2010 - 09:45 PM.
#5 mike.
mike.
  • 6,176 posts
Mine runs better with it plumbed in - No matter what the weather.
#6 james962
james962
  • 2,677 posts
Posted 23 June 2010 - 11:15 PM
How have you routed your pipes duds if you have no heater take-off from the top of the head?
#7 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 23 June 2010 - 11:56 PM
I agree with BMC, you wont get any advantage from having it plumbed in. In my oppinion it just clutters up the engine bay with more hoses.
#8 Ethel
  • 26,580 posts
Posted 09 September 2010 - 10:33 AM
The difference with twin carbs is that the jets can squirt directly into the head; a single carb is more likely to put fuel on the manifold wall and the tract is longer for heating to have more effect.
#9 benb12
benb12
  • 1,483 posts
Posted 09 September 2010 - 11:27 AM
You should get better atomisation with it plumbed in whatever the weather.
