Rust Bubbling On Door Skin
9 replies to this topic
#1 mini_hobnob
mini_hobnob
  • 75 posts
Posted 25 June 2010 - 11:00 AM
I've got a small amount of rust bubbling on the bottom of my door skins, i was wondering if there is a way of repairing it without reskining or patching it. i.e. sanding it down and repainting a section. Or is the problem more likely to be internal?
#2 azzysef
azzysef
  • 30 posts
Posted 25 June 2010 - 11:33 AM
the problem could be either if the rust is bubbling try poking it with a screwdriver or something. if it goes through and the holes arent big you can just use the old method of some filler and sand it smooth then repaint it simple, if the holes get bigger though then a spot of welding is needed but otherwise a very small job indeed
Aaron
#3 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 25 June 2010 - 11:34 AM
However the longer you leave it after rust as started, the more chance there is that the frame of the door will need repair work as well.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,096 posts
  • Name: Neil
Posted 25 June 2010 - 06:26 PM
I'm afraid you will need to bite the bullet and repair it properly either by reskinning or replace the lower section.
As Deathrow has mentioned if you leave it then it will start to eat into the door structure if it hasn't already. I know its not what you want to hear but if you intend on keeping your car its better to sort it now rather than later when the damage has spread even further.
#5 mini_hobnob
mini_hobnob
  • 75 posts
Posted 26 June 2010 - 05:03 PM
Hmm ok, I want to keep this one so I guess I'd better get them repaired properly. Thats the new interior out the window for the time being then :( lol
#6 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 26 June 2010 - 05:23 PM
my door had bubbling not quite as bad as that but when i sanded it down the skin wasnt pulling away and nothing was rotten. it was only slightly pitted and it took a light layer of filler(the pits were no more than a mil deep) so u could be lucky but always best to anticipate for the worst
bare foot photography?!?!?!
#7 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 26 June 2010 - 05:59 PM
If you do want to do a temporary repair that will last a fair while, remove the door card from the inside of the door and look at the inside surface of the door skin. In order to have that rust bubbling through to the outside of the skin, you will probably find that the inner side of the door skin is quite corroded and that the corrosion has crept a fair few inches up the inside of the door skin.
Attack the inside surface through the apertures in the inner door with a "dremel" type flexible rotary tool, to remove as much of the corrosion as possible. Then coat the area with a chemical rust converter/killer followed by a cellulose based red oxide primer and finally a top coat of smoothrite or some such like.
Leave the inside of the door to dry out and harden fully for a good few days before coating as much of the inner door skin as possible with waxoyl. (Make sure that you ensure that you havent blocked the drain holes at the bottom of the door though!! Once the waxoyl has dried, you can then use the standard sand and fill on the outer side of the skin, before re painting the outside of the door. (remove / chemicaly treat the rust on the outside too obviously)
This is only a temporary repair and is not a comparable substitute for welding in new metal. It will however slow the rot down significantly . I did this to my doors once, when I didn't have the time or the cash to go for a reskin and it kept the rust at bay for two winters on a daily driver. Don't be tempted to just simply sand and fill the outside though, as you will just find the rust bubbling through again about two weeks after the next rainfall!
#8 mini_hobnob
mini_hobnob
  • 75 posts
Posted 26 June 2010 - 06:10 PM
Oh ok this sounds pretty good and sounds fun lol, as funds are pretty low at the moment and i'm going to uni in september I might give this a go.
Ohhhh yes! bare foot photography you spotted it, nothing better than driving bare foot on a sunny day lol
#9 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 27 June 2010 - 08:22 AM
"sounds like FUN"???.... you have a very strange idea of fun!!.. Personally I'd say its a tedious, filthy and time consuming job that involves a lot of swearing as you scratch and cut the back of your hands to hell on the edges of the inner door apartures!!... but hey.... if you like that sort of thing??
If your gonna do it then I'd recommend this stuff as a decent chemical rust killer/stabiliser:
http://www.jenolite...._automotive.htm
they also used to do a twin pack rust killer and red oxide primer set, that contained easily enough of both to do the bottom of both doors, not sure if its still available but might be worth a look?
#10 jack_marshall
jack_marshall
  • 2,540 posts
Posted 27 June 2010 - 03:18 PM
9 times out of 10 the corrosion will be coming from inside the skin and therefore will need at least reskinning, likely to need a lower frame repair.
If your like me and hate doing a job twice, either leave it and live with it or do it properly!
