Rear Diffuser
21 replies to this topic
#1 turbominicooper
turbominicooper
  • 295 posts
Posted 28 June 2010 - 05:59 AM
Has anyone ever fitted one of these to theres? whats the down force like with on? is it worth it?
#2 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 28 June 2010 - 07:37 AM
your thinking of fitting that to a mini?
#3 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 28 June 2010 - 08:19 AM
I personally have never seen one of these fitted to a mini......Down force.... how fast will you be going?. I think minis handle just fine without the need for.....Down force....But having said that, you will have something not many others have. If it dosnt weigh much and doesnt abverselly affect the handling then why not..
#4 satvinder
satvinder
  • 557 posts
Posted 28 June 2010 - 08:49 AM
theres a guy on here who does hill climb ands got a zcar mini hes got a rear diffuser he made. ill have to think of his name
#5 Yoda
Yoda
  • 1,958 posts
Posted 28 June 2010 - 08:52 AM
If the z car mini is rear wheel drive, then i can understand fitting one, but on a front wheel drive why would you want to have downforce?
#6 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 28 June 2010 - 09:18 AM
Mini's arent Areo dinamic anyways that thing would be useless ;]
#7 turbominicooper
turbominicooper
  • 295 posts
Posted 28 June 2010 - 09:54 AM
well this one is classic mini designed and carbon fibre so therefore lightweight... just thought it would be something new to the table. think ill go for it - post some pictures when its sorted
#8 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 28 June 2010 - 10:09 AM
You understand what its for dont you??? They clean the air flow as it leaves from under the back of the car, Only works when you are going very fast. At slow speeds its going to be useless, But as i said before, your choice really.
#9 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 28 June 2010 - 10:10 AM
i am gettign the imrpession from some peoples reply, that they think this is a spoiler and is bolted to the roof. just so people know, this is not a spoiler it is a defuser that is bolted to the underside of the car to help with the aerodynamics of the underside of the car, as well as to try and smoothly replace the air, that the car has forced out of the way.
carbon weazel also makes them:
EDIT: beaten to it ;)
Edited by stardude, 28 June 2010 - 10:12 AM.
#10 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 28 June 2010 - 10:35 AM
Mmmmm.. not sure i like that.. Nice wheels though,
#11 Pooky
Pooky
  • 5,691 posts
Most probably unnecessary on a road car. No doubt it helps smooth out the flow around the rear subframe and rear valance.
Whether it works or not, it looks the nuts! ;)
#12 turbominicooper
turbominicooper
  • 295 posts
Posted 28 June 2010 - 11:02 AM
yeah we know its not a spoilre lol hence rear diffuser.
and yeh the whole point is for extra down force while travelling fast.
this topic was just to see if anyone has one fitted and the pros/cons.
Topic CLosed
#13 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 28 June 2010 - 11:09 AM
If you want down force fit a spoiler!! I am not sure but i think diffusers clean the air turbulance as it leaves the back of the car therefore reducing drag allowing greater straight line stability. I might be wrong but I dont think it will help down force unless used in conjunction with side skirts in order to create a vacuume under the car. And im also pretty sure a mini design will not lend itsellf to this kind of aerodynamics.
#14 turbominicooper
turbominicooper
  • 295 posts
Posted 28 June 2010 - 11:19 AM
i was thinking spoiler but there a bit 'Max Power' for me - i can only give this a bash and if i dont like it sell it. cheers
#15 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 28 June 2010 - 01:24 PM
I've seen them fitted to quite a few Hill Climb and Sprint Minis over the years but not on a road car. To be effective they need to run fairly close to the road surface which may be an issue on the road. But there again, if you want it just for looks none of the above matters, but you will have to find somewhere else for your exhaust back box to live.
