Rear Radius Arms
Posted 28 June 2010 - 09:29 AM
How easy is it to replace the arms and change it to 12" drums on the rear. I do not have extensive mechanical experience but i would like to give it a go but if it is going to be too difficult then i do not want to bite off more than i can chew.
Also, what tools will i need on top of the obvious jack and spanners
Tim
Posted 28 June 2010 - 09:32 AM
Couldn't help you with the fitting though as not done it myslef yet.
Posted 28 June 2010 - 09:41 AM
Posted 28 June 2010 - 09:47 AM
Plenty of penetrating fluid is needed.
To remove
take off the wheel, remove shock absorber. disconnect flexbrake pipe off the radius arm. you will need to clamp the hose save losing all the fluid.
disconnect handbrake cable
Then there are four bolts that hold the outer bracket on, two are hidden and probably covered in dirt and mud. These are the ones that can snap.
One last nut is on the end of the radius arm where it goes through the subframe
problems that can happen, seized bolts snapping, brake pipes corroded may snap.
bleed nipples on brake cylinders can snap.
Posted 28 June 2010 - 09:52 AM
Posted 28 June 2010 - 09:57 AM
what about were the flexi pipe joins the metal pipe and is connected through the bracket on the radius arm?
Posted 28 June 2010 - 10:00 AM
From what you guys have said it seems like something that i could deffinately get stuck into and sort out myself.. my only hold up is what happens if a bolt does snap?? any other ways to remove it or does it just need to be drilled out?
Posted 28 June 2010 - 10:08 AM
Flexi pipe male thread goes through bracket on radius arm, then rigid pipe from slave cylinder connects to that via a female fitting.
Shows bracket that the pipes should go through. Even removing backplate the pipe would still be connected to radius arm
just noticed midridge2 beat me to it
Edited by lrostoke, 28 June 2010 - 10:13 AM.
Posted 28 June 2010 - 10:13 AM
I know one arm is bent because my brother handbraked it into a curb before i bought it off him! Luckily this was the only damage caused!!
Before attempting to loosen the bolts, lightly hammer the bolt to loosen the grip of any rust and drench in penetrating oil. Don't put any pressure at all on them, this is one area that needs time!
I had to drill out one of mine that sheared, luckily the welded nut on the other side was accessible so I simply drilled out the bolt and ground down the nut, just used a new bolt and nut, the others are more difficult to sort out as they aren't accessible from the other side.
Posted 28 June 2010 - 10:24 AM
As you say the arm was bent by the wheel ramming the curb. I would suggest you check all the components as pictured. Something else might well be dammaged. The three bolts you can see between the brake shoes hold the back plate on to the arm. I fitted new bearings and seals while it was in bits even though nothing wrong with the old ones.
Posted 28 June 2010 - 10:46 AM
Posted 28 June 2010 - 11:15 AM
Posted 28 June 2010 - 01:13 PM
Posted 28 June 2010 - 01:40 PM
Cheers for the help tho.. muchos appreciated
