998cc Rev Limit.
10 replies to this topic
#1 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 28 June 2010 - 06:56 PM
Hey guys,
i have a 998cc with a stage 1 kit fitted. i havent got much knowledge at the moment with mini's slowly getting there. have i got a rev limiter? of not, how far past the red line can i take it without damaging anything? or am i highly likely to damage something if i do take it past?
#2 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 28 June 2010 - 07:01 PM
There are no rev limiters on minis, dont go in the red because you will do damage Thats why its there. RED = danger. About 5500 is a safe limit and you wont get much if any more power by reving it to death.
#3 Jet_black
Jet_black
  • 325 posts
Posted 28 June 2010 - 07:03 PM
On my stage one 998 the power is gone by about 5600 rpm which is before the red line so there is no need to go any higher.
#4 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 28 June 2010 - 07:13 PM
Over Rev the car and you'll cook:
Block
Pistons
Valves
Thermo Stat
Gears
Big End Bearings
Con rods
Water Pump
#5 CaptainBland08
CaptainBland08
  • 675 posts
Posted 28 June 2010 - 07:37 PM
i like to keep mine bellow 4.5... gives good power up to there, but anything past isnt worth the risk in my opinion... all my power is lower down anyways...
#6 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 28 June 2010 - 09:30 PM
Stage 1 998 should be good for 6000. No point taking it there with a standard cam though.
#7 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 28 June 2010 - 09:37 PM
Tom's right, stage 1 998 will go to 6000 rpm. But, there's nothing there power wise so it's pointless. Change around 5500 and you still be pulling away on power and not losing it.
#8 HARBER07
HARBER07
  • 4,498 posts
Posted 28 June 2010 - 09:41 PM
to be honest I can't really see any damage occurring anyways unless your sitting it on the redline for hours :cry:. The valves should bounce well before the rods fly through the block! I take mine to 7000 regularly - standard crank, standard rods, standard block, thermostat, water pump, bearings etc. etc. etc.....
#9 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 28 June 2010 - 09:44 PM
Block
Pistons
Valves
Thermo Stat
Gears
Big End Bearings
Con rods
Water Pump
Doubt it.
I agree with tom. A standard engine isn't going to kill itself with the occasional rev up.
#10 Pooky
Pooky
  • 5,691 posts
Posted 28 June 2010 - 09:46 PM
I have a rev limiter :cry:, can't remember what it's set at tho 6500 I think but then I do have a fairly tuned small bore, don't take it all the way up often.
#11 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 28 June 2010 - 09:51 PM
would have to say, if you hit the red line once or twice for a very short amount of time every so often, i cant really imagine a huge amount of damage will be done!
