hope some1 can help paul
Edited by widg, 30 June 2010 - 07:16 PM.
Posted 30 June 2010 - 06:42 PM
Posted 30 June 2010 - 07:01 PM
Posted 30 June 2010 - 07:08 PM
Posted 30 June 2010 - 09:59 PM
Posted 01 July 2010 - 06:02 AM
ye took all plugs out and cranks til gauge wouldnt go any moreWith the engine fully warmed up you should be around 140psi to 170psi depending on if the compression been altered,
70 psi is very poor,piston rings if you lucky,if not pistons and rebore.
If compression was ok and just smoked a bit it would most likely be valve seals or guides,but unfortunately for you compression is way down.
This is not to be confused with compession ratio(cr).
you did crank it with all plugs out til the gauge stopped climbing i assume?
Dave
Posted 01 July 2010 - 07:23 AM
Posted 01 July 2010 - 11:29 AM
Posted 01 July 2010 - 05:24 PM
no on a warm engineDid you run the test on a cold engine?
Posted 01 July 2010 - 09:39 PM
hi got a 1985 1000cc engine which smokes alot when driving. i have done a compression test and have the readings. mine read between 60-70 psi on all 4 cylinders is this good or not? any thoughts what it could be?
Posted 01 July 2010 - 11:34 PM
What mileage has the car done and what colour is the smoke?? These are very low readings but before righting the engine off i would remove the cylinder head.
Badly worn seats,valve stems and seals can cause an engine to smoke alot.
Posted 02 July 2010 - 12:35 AM
Posted 02 July 2010 - 09:53 AM
Posted 02 July 2010 - 04:06 PM
