Rover Mini Stereo
6 replies to this topic
#1 kevr1
kevr1
  • 11 posts
Posted 30 June 2010 - 11:18 PM
hi guys just wondering if you guys can help, ive got a standard radio cassette in my cooper and switching it on displays an "err" code, is there any way i can resest etc? manyt thanks,kev
#2 Nu2mini
Nu2mini
  • 442 posts
Posted 02 July 2010 - 07:43 AM
Is this the first thing you see on the display after switching on the radio ?
Turn the radio off and then on you should see the display show -C- (Dash C Dash)
If it shows ERR after this the radio has lost it's security code. Happens when the battery had been disconnected.
If you've lost the code you'll need to get it decoded. Plenty of folks around can do this, Google Radio decode or e-bay. You'll need to give them the make/model and serial number of the radio. This info should be on a sticker somewhere on the radio. You'll need to take it out of the dash to see it.
#3 rocketbeta
rocketbeta
  • 56 posts
Posted 07 August 2010 - 07:55 PM
I put the wrong code in and got the "ERR" message. How do I reset it so I can put the right code in? Do I have to unplug the battery or wait for it to reset itself?
Thanks,
.ant
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 August 2010 - 09:07 PM
Leave it disconnected. It might take a while. Each time you enter the wrong code, it adds more time until it will reset.
#5 rocketbeta
rocketbeta
  • 56 posts
Posted 07 August 2010 - 09:15 PM
so that means I should disconnect the battery and wait a few hours right? I have the correct code but I fat fingered it. =(
#6 rocketbeta
rocketbeta
  • 56 posts
Posted 07 August 2010 - 09:57 PM
Ok I left the battery connected and about 2 hours later I was able to put the code in. Now I'll be more careful when I put the code in.
Thanks,
.ant
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 August 2010 - 10:03 PM
Yes sorry, you're right. It has to stay connected and off. It has a timer inside which won't run if it's disconnected!
