Underdash Support
4 replies to this topic
#1 lyle.m23
lyle.m23
  • 13 posts
Posted 07 July 2010 - 12:33 AM
hi i just got an autoleads underdash iso support and not to sure what to fit it with any idea?
iv seen a few on here with the exact same thing so what did yous use ?
thanks
#2 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 07 July 2010 - 08:49 AM
thanks
Do you mean to hold head unit? if so have similar a black plastic tray with a normal single din sized hole, I needed to use blocks of wood under and each side of head unit to get it level in slot still moves about some but ok.
For ease I ended up zip tying it to lower dash rail under the passneger side looks pretty good and means its not like solid mounted either so less vibes to it, I needed to drill one hole in rail and used an existing and had to trim tray to fit far enough back.
See picture attached, I have tidied up all wiring now and i think looks quite neat, but do need to use remote on head unit as its to far away to reach over whilst driving lol!
#3 lyle.m23
lyle.m23
  • 13 posts
Posted 07 July 2010 - 09:28 PM
yes thats exactly what i ment thanks
#4 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 08 July 2010 - 08:13 AM
No worries zip ties are your friend in this instance, and i have used them for many things on mini, speaker pods are held on with them as my alarm box to.
As long they dont pass through a hole that has sharp edges should last for ages, and provides some give for vibes etc.
#5 daveholman
daveholman
  • 183 posts
Posted 09 July 2010 - 02:01 PM
My Italian Job had a stereo frame fitted under the dash as standard. The fixing holes are kind of under the front dash rail, if you look from underneath you'll be able to see them. I should think a couple of nuts and bolts will do the trick although the factory frames had a fixing at the back as well, you could always make something out a piece of metal bracket though.
