Mk1/ Van/ Pickup Fresh Air Intake Tube
5 replies to this topic
#1 mini-man-dan
mini-man-dan
  • 2,684 posts
  • Local Club: J19 Mini Owners Club
Posted 07 July 2010 - 08:47 PM
Hi All
Have a Mini Pickup that has the same layout bulkhead wise as a Mk1. What do people use as the fresh air intake pipe that runs along the driver's inner wing, and through the hole in the bulkhead then down to the heater unit?
I have the later style heater in it, not the original recirculation type.
Dan
Edited by mini-man-dan, 07 July 2010 - 08:48 PM.
#2 mini-man-dan
mini-man-dan
  • 2,684 posts
Posted 08 July 2010 - 09:03 PM
No-one...?
#3 Pooky
Pooky
  • 5,691 posts
Posted 08 July 2010 - 09:07 PM
A bit different I know but I got this stuff from Car Builder Solutions
What size would you need?
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 09 July 2010 - 12:54 AM
The Mk1 hose is an odd size. You may have more luck sourcing the smaller diameter Mk2 hose and the adapters to "enlarge" its ends to fit the heater and the intake scoop. If that's not successful, measure the OD of the heater hose connections (3-1/4" rings a bell) and start browsing through online industrial suppliers catalogs looking for corrugated hose. Plastic holds up better than the treated paper hose material.
#5 andyapanel
andyapanel
  • 627 posts
Posted 10 July 2010 - 11:53 AM
Hi All
Dan
#6 andyapanel
andyapanel
  • 627 posts
Posted 10 July 2010 - 12:04 PM
Attached File  DSC00430.JPG   778.5K   4 downloadsAttached File  DSC00433.JPG   745.73K   4 downloads
Attached File  DSC00434.JPG   835.55K   4 downloads
I bought the pipework and brackets , made a hole in the bulkhead and a cylindrical flange for the air pipe to attach inside.
As I replaced the entire front end, I used a later style inner wing with a hole for the fresh air pipe.
I used a small Hammerite tin to form the flange around-just the right size, and a piston ring compressor to lock it in position while I welded.
