Door Hinge Pins
6 replies to this topic
#1 100ev8
100ev8
  • 622 posts
Posted 10 July 2010 - 12:58 PM
any one know where i can get any mini door hinge roll pins from ? tried usual mini places but they say only mk1 available . i dont really want to pay £15 + per hinge when i know roll pins are only pennies
rob
#2 miniobsessed
miniobsessed
  • 211 posts
Posted 10 July 2010 - 01:10 PM
If you are trying to replace the pins in external hinges they are not roll pins. They are a solid pin that is knurled at one end to stop it falling out. The 15 quid should also include a new bush for the 'inner' part of the hinge.
It would cost more more than 15 quid to have these parts machined up for you...
#3 100ev8
100ev8
  • 622 posts
Posted 10 July 2010 - 06:44 PM
internal hinge . sorry should have made it clearer
rob
#4 GraemeC
GraemeC
  • 7,451 posts
Posted 10 July 2010 - 09:22 PM
I would ask why you need them first - the pins are probably the last part to wear in the hinges due the material they are made from, ie any play is likely to be due to the hinge bodies being worn.
#5 kcrompton
kcrompton
    Starting My Mini Up
  • 3 posts
Posted 08 August 2010 - 07:58 PM
#6 kcrompton
kcrompton
    Starting My Mini Up
  • 3 posts
Posted 08 August 2010 - 08:00 PM
I have just removed my internal door hinges and extracted one roller pin and it is visibily worn. I will be trying to source either the same size pin or going to a larger size and reaming the hinges themselves. Roller pins are readily available on the internet.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 08 August 2010 - 08:08 PM
You'll have to source them from a hardware supplier if you want to do this, they were never sold as a part. The hinges are complete units.
