OBP are manufacturing a 'easy to fit' pedal box which is designed specifically for the Classic Mini, you can adjust these pedal boxes so you have full control over the brake system!
MINI PEDAL BOX
We do two different pedal boxes, ones with a hydraulic clutch and ones with a cable clutch, also there's different types of kits, depending on what you need, from a simple/standard kit, to comprehensive kit, prices vary!
http://www2.obp.uk.n...6457adcd4068647
This pedal box has been designed specifically for the Classic Mini we have worked very closely with a Mini specialist to create a hi-performance system that is easy to fit. We are confident that our Mini bias brake pedal box is by far the best solution available on the market. This is a total replacement pedal box, not an add on part that does not work. We have tested and designed the 6:1 pedal ratio to give optimum pedal performance. All our pedal boxes are manufactured in our UK based factory, this is how we can maintain the highest level of quality control. The Mini pedal box is a light weight mild steel under-slung pedal box design, that offers the driver the highest level of efficiency in this critical area
If your wanting to buy one of these or any other product we manufacture, you need to PM me for the discount code, then order via phone or email so we can process the discount easily.
email: [email protected]
Any more info needed or questions, then feel free to ask them, either PM me or reply here.
Cheers all.
Edited by obp.ltd, 14 July 2010 - 01:22 PM.
