I know this is a lot of text but please reply if you can... running out of time.
...... in the past 12 months i have had to take my exhaust apart and re-seal it 3 times as it keeps blowing at the joint of the cat to the stainless pipe attached to my back box.
When i rebuilt my mini i took off the standard exhaust back box etc just leaving the standard down pipes and cat. i then cleaned off all the rust that formed on the joint flange and then smeared exhaust assembly paste on it and bolted it together to my new stainless link pipe which was sealed and clamped to my twin DTM back box etc.
Question is..... the back box is secure, all the rubber hanger brackets are secure but the joint in question keeps blowing, the mot is due again next monday so i need to strip it and seal it again. i have noticed that there are gaskets available for cat joint.... do i need one of these or have i done it right already?
If i need a gasket do i need to use the paste as well as the gasket or just pinch the gasket between the two flanges? the gasket on minispares looks thiner than the gap and looks like steel? i have heard of thicker copper gaskets that squash and seal before but not sure.
Any help would be great....... was also thinking of replacing my cat with a link pipe, is this worth doing as i'm led to believe the mot guy has a bigger tolerance to play with regards emissions and it is better on performance? any input?
Regards,
Chris
