hi, i want some new gauges but, im unsure which to get, ages ago i bought a braided oil pressure pipe, does anyone know if i can use this with any other mechanical gauges?
or would i need on of these
http://cgi.ebay.co.u...=item3a5cd39457
does this give an accurate a reading as the tim/smiths mech ones would?
these loook pretty cool, http://cgi.ebay.co.u...=item3caf06a317
any ideas will be nice pleasee i need volts oil pressure water temp etc cheers:)
Gauges
devon2493
, Jul 15 2010 11:50 AM
3 replies to this topic
Posted 15 July 2010 - 11:50 AM
Posted 15 July 2010 - 12:04 PM
i fitted a mechanical (i think) oil pressure one which has the oil flowing into it. all i did was fitted a tee peice into the block so i could still connect my light up and then got a single length of pipe and ran it through the bulkhead to the guage, didnt have one of those sender units. i also got a vaccum guage and an amps guage. the vaccum one looks cool when driving along as it shows how much fuel and air your using so its constantly moving - but is pretty useless and just a distraction! i drilled and tapped my inlet for this but i heard you can use your brake servo pipe (if you have one) - anywhere where between the carb and the block really. the amps i havent figured out yet so im going to swap to voltmeter as they are MUCH safer and easier to install.
