Hopefully My Last Fiesta Brake Question
9 replies to this topic
#1 kez_19
kez_19
  • 946 posts
Posted 18 July 2010 - 08:19 AM
hi all
finally i have got the second calliper i needed and everything all painted up and started to fit it yesterday but when i came to put my wheel on i found the calliper was still touching the inside of the wheel do i have to grind the calliper or do i have to use a spacer? I don't remember it saying anything in the video or on here saying i needed spacers or that i needed to grind off the calliper or is it just the wheels i have are incrediably small inside for some reason (i am using some weller copy's)
any help will be most appreciated
michael
#2 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 18 July 2010 - 08:54 AM
The conversion wont fit under all 10" wheels what wheels are you using?
#3 kez_19
kez_19
  • 946 posts
Posted 18 July 2010 - 09:09 AM
they are some weller copys i think they are called jollys
#4 paul6266
paul6266
  • 482 posts
  • Local Club: Retro Classics
Posted 18 July 2010 - 05:42 PM
you did change the rive flanges for metro ones didnt you......
#5 paul6266
paul6266
  • 482 posts
you did change the drive flanges for metro ones didnt you......
#6 1984mini25
1984mini25
  • 8,786 posts
Posted 18 July 2010 - 05:55 PM
The mk1 fiesta set i have fit quite nicely with room to spare inside the genuine 10x5 Wellers i have.
#7 kez_19
kez_19
  • 946 posts
Posted 19 July 2010 - 09:26 AM
as far as i know i have metro hubs i got them from the classified section here. But what difference could that make my wheels touch the edges of the callipers
Is there much difference between mk1 and the mk2 callipers i have?
#8 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 19 July 2010 - 10:17 AM
you need the flanges from a metro turbo, the hubs wont do you any good.....
#9 kez_19
kez_19
  • 946 posts
Posted 19 July 2010 - 11:47 AM
i have the hubs that have been drilled up to take the fiesta calliper bolts.
As far as i know the flanges are metro ones but how can i see to be sure??
Looking at the wheel and the flange it looks like i will need 10mm spacers
#10 bmcecosse
bmcecosse
  • 9,699 posts
Posted 19 July 2010 - 03:41 PM
You should NOT use Metro hubs - the suspension geometry goes to h3ll. You DO need Metro vented disc drive flanges.... Mine fitted fine under the Exacton alloys - plenty of room in fact - they were MK I F calipers. You could fit a 1/8" spacer - won't do any harm - or simply file a bit off the caliper if it's just at the edge. But honestly - I would get better wheels!
