Fse Powerboost Valve What Is It Help!
Posted 20 July 2010 - 09:09 PM
Has anyone got one fitted?
http://www.motorspor...a...1H&PID=2627
Many Thanx
Posted 20 July 2010 - 09:12 PM
The Power Boost Valve is a high performance tuning part which replaces the original equipment valve (fitted to the vehicle). New Power Boost Valves are pre-set with a maximum fuel pressure of 2.5, 3.0 or 3.5 bar, depending on the vehicle in question, and similarly (to the original valve) the fuel pressure is reduced by 0.5 bar approximately at idle. This will produce a healthy, strong fuel mixture strength which will instantly improve the drivability of your vehicle, providing:-instant throttle response, removal of performance flat spots, faster acceleration, extra engine performance. This valve has an adjustable fuel pressure, effected by the movement of an adjustment screw on the crown of the unit. These units are mechanical and are considered maintenance free.
Posted 22 July 2010 - 05:58 PM
Posted 22 July 2010 - 06:18 PM
as for economy i am not sure what difference it will make but it should improve performance
michael
Posted 22 July 2010 - 06:52 PM
that just looks like a fuel pressure regulator, your injectors are fired by electric pulses and fuel pressure is held in the rail if your getting more pressure in the injector and rail before it fires your going to atomse fuel more and supply more of it, as you know more fuel along with more air means more power, weather you will notice it on a standard engine? who knows your injectors will have to be able to cope with this of course
Edited by mini93, 22 July 2010 - 06:53 PM.
Posted 27 July 2010 - 12:32 PM
Posted 27 July 2010 - 01:08 PM
Posted 27 July 2010 - 01:19 PM
I've seen these before but i honestly cant see it making a single difference on a carb engine as the petrol is taken from the float bowl and controlling the pressure of the fuel wont make a difference to the amount entering the carb.
have a look see what section this is in, hence why i was talking about fuel injectors
Posted 27 July 2010 - 02:05 PM
Posted 27 July 2010 - 11:37 PM
It's only an adjustable fuel regulator but it does make set up a lot easier when on the rollers!!
I also fitted a pressure gauge to mine as they come without as standard.
See attached instructions/data - [attachment=101143:Power_Boost_Valve.pdf]
and link
