Look At The Wear On These Con-rod Shells.
16 replies to this topic
#1 m1n1
m1n1
  • 768 posts
  • Local Club: I'm unsociable
Posted 20 July 2010 - 09:52 PM
Reground crank and bearings bought from med in 2005.
20 000 miles covered since then
no noises from the engine, just a stripped for a gearbox rebuild and check-over.
can anyone shed light into why one of the shells from each rod is worn down to the copper on one side? the shell was the bottom one. Crank seems unworn and smooth, the shell is smooth also i.e. no scoring.
Attached File  IMG00177_20100720_2232.jpg   96.89K   20 downloads
Attached File  IMG00175_20100720_2232.jpg   194.05K   19 downloads
#2 MRA
MRA
  • 7,607 posts
Posted 20 July 2010 - 09:56 PM
incorrectly sized thrusts is normally the cause of this one :)
I would also say that the worn one is normally the top shell, and that opposite opposed is also worn to a lesser state, this is caused by the crank moving along the block and the conrods having to "tip" over to carry on working, canting over on the big end journal :P
#3 m1n1
m1n1
  • 768 posts
Posted 20 July 2010 - 10:13 PM
thrusts. ok will get measuring with the dti.
#4 alexcrosse
alexcrosse
  • 3,786 posts
Posted 20 July 2010 - 10:24 PM
yep, i agree with martin, thrusts :) you running helical drop gears?
how did your movie plans pan out?
Edited by alexcrosse, 20 July 2010 - 10:24 PM.
#5 m1n1
m1n1
  • 768 posts
Posted 20 July 2010 - 10:52 PM
Yes helical std A+ drops. The idler was rattling as the thrust washers were incorrect, new roller bearings and thincker washer has cured that. I also have a new primary gear coming in the post, and a set of rings.
will measure up tomorrow and order new shells and prob next size up c shape crank thrusts as i was supplied std ones 5 years ago.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 July 2010 - 11:03 PM
One size up? There are only 2 sizes, to make an in between set use one size on one side and the other on the other. Measure it well and make sure you get them in the right way around.
#7 R1minimagic
R1minimagic
  • 4,660 posts
Posted 21 July 2010 - 07:51 AM
Would also be worth checking the pistons, rings, and bores for wear as that area could be affected too.
#8 MRA
MRA
  • 7,607 posts
Posted 21 July 2010 - 08:03 AM
I would also check the crank thrust faces.........
If in good condition then I would check how much end float and set it from there.
#9 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 22 July 2010 - 01:43 PM
Has anyone realised how much slop there is in an A series bottom end? how would a slightly larger thrust clearnce cause this type of wear on the big ends? Dont forget that two of the big ends are oposites, so the wear patch on at least two of the bearings would be on the oposite sides to the way they are shown in the picture. If it was thrusts that caused this, you might expect to see the wear patch in the same orientation on all big ends
Plastigauge all the bearing clearances. :)
#10 Sprocket
Sprocket
  • 7,266 posts
Posted 22 July 2010 - 01:49 PM
Dan there are infact four sizes available, those being STD, +0.003", +0.005" and lastly +0.030". The 0.030" thrusts are used in such a way that you measure your thrust clearance using a standard set of thrusts, then have the +0.030" thrusts surface ground to the correct thickness.
You are correct however in the way you can achieve more than just the four stated sizes by mixing and matching different sets, per side. If going to the trouble to have a set of the 0.030 thrusts ground, consider using a standard set on the thrust side, and the ground 0.030 on the non thrust side, that way if you rebuild the engine, you can slip in new pair of standard thrusts without having to go to all the trouble of getting another set of 0.030 thrusts ground down.
#11 m1n1
m1n1
  • 768 posts
Posted 22 July 2010 - 08:27 PM
im not an expert. i seem to learn from my mistakes but after 10 years am getting there! not yet cleaned up the block and put my dti on the crank but if i push/pull on it i can feel a tiny bit of movement. (But not enough to slow down the engine when clutch was depressed) which happened to me once ages ago.
#12 m1n1
m1n1
  • 768 posts
Posted 22 July 2010 - 08:59 PM
okay, i have 5 thou movement when i pull it back and forwards.
this is to much yes?
#13 R1minimagic
R1minimagic
  • 4,660 posts
Posted 23 July 2010 - 07:33 AM
Did you check the pistons?
#14 Sprocket
Sprocket
  • 7,266 posts
Posted 23 July 2010 - 08:15 AM
0.005" is fine, its at the upper limit, but fine. If you are that concerned about it, I would buy some +0.003" thrusts and use just half of that set on the non thrust side, then recheck that the clearance is 0.0035"
As I said, I doubt the thrusts have anything to do with the wear on the big end bearings.
What do the Main bearing shells look like?
Plastigauge all bearing clearancies :)
#15 m1n1
m1n1
  • 768 posts
Posted 23 July 2010 - 09:22 AM
hmm. my pistons are in good condition - a few marks in front and behind but not side to side but im happy with them.
the mains are the same, in that the bottom half is wearing worn to the copper.
i will have to mail order a plastigauge, cant think where to get it round here.
Attached File  IMG00204_20100723_1011.jpg   431.33K   18 downloads
do you think that the crankshaft has not been ground to size correctly?
