Does Skimming Change The Valve Clearance?
Posted 23 July 2010 - 01:24 AM
Will
Posted 23 July 2010 - 08:34 AM
If it was running fine before you adjusted the timing I'd start by re-checking your timing
Posted 23 July 2010 - 08:53 AM
Posted 23 July 2010 - 12:15 PM
You should never assume that a carb off one engine will be pre-adjusted to run right on another engine. This would be particularly true if the carb has been sitting around "off" the engine for a while as you don't know what someone may have done to the adjustments "just to learn" what each screw does.
Also make sure the general condition of the carb is OK before trying to adjust it.
The piston must be 100% free to rise and fall.
The damper must have oil in it.
Go through a complete tune up.
Start with adjusting the valves clearance on a cold engine.
Move on to setting the points gap, then the static timing.
Make sure the engine will start.
Then move on to the "pre-tune-up", basic carb settings. (The settings you make on a rebuilt carb just to get the engine started).
Then start the engine and when it is at temperature, set the mixture, idle, and fast idle.
Posted 23 July 2010 - 10:48 PM
"thou" is the usual abbreviation for thousandths of an inch. Skimming 12 thou off the head will make the engine shorter, relative to the pushrods and the lever ratio of the rocker gear will magnify it a bit. Since the valve clearance should be 12 thou yours would be less than zero without any adjustment.
Posted 24 July 2010 - 10:15 AM
Posted 24 July 2010 - 11:07 AM
Having had the head skimmed, the compression ratio has been increased. You may need to advance the ignition slightly otherwise the air/fuel mixture may incur detonation (mixture combusts due to compression rather than spark plug).
Higher compression ratios require less advance, if anything, because the fuel/air molecules are closer together and react (burn) faster. If you advance the ignition then it has longer to burn before tdc which means more pressure at tdc and so even more heat to get rid of to avoid "dieseling" the next cylinder full.
Posted 24 July 2010 - 01:47 PM
Yes, but it is a controlled burn. If you allow the fuel to detonate from the compression ratio being too high then you risk putting a hole in the piston crown as there is more than one flame front in the cylinder.
I only meant a very small amount of advance. Detonation will increase the cylinder pressure far more than a degree of spark advance
Posted 24 July 2010 - 01:58 PM
