Filter King Fpr Leaking Replacements?
10 replies to this topic
#1 fishey798
fishey798
  • 562 posts
  • Local Club: Mini Rebels
Posted 23 July 2010 - 07:21 PM
Im running a pacet solid state fuel pump and a filter king fuel pressure regulator on my 1380 with hif44.
The problem i have is the filter bowl leaks! I have replaced the seals tightened the nut up as tight as it will go, the bowl has no cracks, i have cleaned the whole setup and dried with compressed air before fitting the new seals.
Anyone else had this problem? Any ideas?
If not, anyone have any better fpr's to use and i will use inline filters.
#2 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 24 July 2010 - 01:10 PM
I have had filter kings fitted to any number of cars and never had this problem unless I put the alloy bowl in in correctly and it jams rather than nips up the seal.
Is there a rubber diaphragm in the housing that seals the pressure spring which may have perished, or is it definately leaking from the bowl?
I don't think there is anything else out there which is better, just dearer and more bling.
#3 fishey798
fishey798
  • 562 posts
Posted 24 July 2010 - 05:59 PM
It is definatly leaking between the bowl and the regulator itself, i have tried a new seal, done it up not too tight, leaked, done up tight, leaked, done up really tight and guess what leaked!!
Are they supposed to be rubber mounted to the car by any chance? I was wondering if it has anything to do with the vibrations going through it?
#4 Kerrin
Kerrin
  • 1,056 posts
Posted 24 July 2010 - 10:15 PM
No, I don't think I have ever seen them rubber mounted.
Is the alloy bowl round, if not could it be missing the seal somehow?
#5 fishey798
fishey798
  • 562 posts
Posted 25 July 2010 - 09:14 AM
Its a plastic bowl one, it has all the seals, i have replaced the seals with new ones to try and stop it! i reckon im gonna buy a new one with an alloy bowl and try that
#6 maccamcvey
maccamcvey
  • 217 posts
Posted 03 August 2011 - 10:43 PM
I am having the same problem! Facet red top pump, filter king clear bowl filter/reg, hiff 44 and 1275 stage 1 spec.
My current theory is the reg cant deal with the pressure the pump is kicking out. was thinking of fitting some kind of restricter ring before the reg.
But not sure if it will work.
Tar
#7 maccamcvey
maccamcvey
  • 217 posts
Posted 03 August 2011 - 10:45 PM
just saw this was added july 2010 not 2011. Did you ever resolve this issue?
#8 thosman
thosman
    Starting My Mini Up
  • 4 posts
Posted 16 October 2011 - 03:48 PM
I've got the same problem on my filterking (with a plastic bowl), it seems that petrol eats away at the plastic bowl and deforms it enough to make it leak. obviously the alloy bowl one is fine, just the plastic one. great design eh...!!
It seems they have started making the bowls out of glass again now, so that seems to be the way to go, if you can get spares?
#9 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 16 October 2011 - 04:48 PM
I had a brand new filter king on my vw bus. Leaked like sieve arond the unions. I was told by Eurocarb to use PTFE tape. Not the described problem but I wasn't too impressed.
Charlie
#10 mike.
mike.
  • 6,176 posts
Posted 16 October 2011 - 05:45 PM
Mine leaked at first. I took it off, got a cloth round the nut on the bottom to give me some grip and did it up really very tight, I mean until my hands were red raw - Hasn't leaked since.
#11 Ethel
  • 26,033 posts
Posted 16 October 2011 - 06:48 PM
http://www.fuelsyste... Regulators.pdf
