Track Rod End Removal
3 replies to this topic
#1 maz72
maz72
  • 95 posts
Posted 24 July 2010 - 11:17 AM
Hi
I need to change my track rod ends ,is it a ball joint splitter i need to get the end out ? I have slackened the nut of the steering rack and taken the top nut off the end just need to know how i get it out so i can turn it,Thanks
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 24 July 2010 - 11:44 AM
Where the bolt comes throu the streeing arm on the wheel hub, screw the nut back on until the nut is just proud of the bolt by about 3mm then hit nut with hammer that stop the thread getting knackerd , if your replacing them as said hit siad bolt bit with big hammer .
#3 rwerry
rwerry
  • 386 posts
Posted 24 July 2010 - 12:06 PM
Hi
You don't need any sophisticated equipment. Just a good hammer. Leave the top nut on the track rod end, but loosened. You're going to need to bash the steering arm until the shock frees up and separates the ball joint taper. As you're replacing the current ends, you can also hit the nut, if necessary. Although this sounds quite brutal, it's an accepted method used by mechanics.
Make sure you count the number of turns when unscrewing the track rod end and screw the new ones on the same amount otherwise you will throw out the wheel alignment.
#4 maz72
maz72
  • 95 posts
Posted 24 July 2010 - 01:15 PM
Sorted it! Thanks guys easy job (with a little help) no more play in wheel.
