Clutch gone completely!
12 replies to this topic
#1 binge
binge
  • 2,508 posts
Posted 25 November 2005 - 04:19 PM
Ok, I drove my car to work today, left it all day. Came out after work and the clutch was completely shagged. :saywhat:
I managed to get it into first, but had to burry the pedal into the carpet. There is nothing in the clutch at all until its about 1cm from the floor. I can push the pedal down with very little force (Unlike it is normally).
Basically the bite is right at the floor now, At one point there was no bite, And I pumped the clutch, Got a bit out of it.
Any ideas?
<|Ben|>
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 November 2005 - 04:20 PM
Bleed the clutch through, and look for leaks...
#3 Jammy
Jammy
  • 25,397 posts
Posted 25 November 2005 - 04:21 PM
Bleed the system through, sounds like you have a leak somewhere if you had a clutch this morning and haven't got one after work.
#4 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 25 November 2005 - 04:26 PM
the same thing happened to me today!!!
#5 binge
binge
  • 2,508 posts
Posted 25 November 2005 - 04:27 PM
where is the bleed nipple?
#6 Jammy
Jammy
  • 25,397 posts
Posted 25 November 2005 - 04:29 PM
On the slave end of the slave cylinder, the thing we told you about last week when you were having problems with your clutch! :tongue:
Will be clearly shown in your Haynes.
#7 1984mini25
1984mini25
  • 8,784 posts
Posted 26 November 2005 - 08:01 PM
Me too :lol:
I've tried this, Worked fine for a day
Now the pedal is the same as it was to start with, Fcuked :lol:
I can't find any leaks
the Slave cylinder was changed a few months back
What next? :cry:
#8 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 26 November 2005 - 08:27 PM
clutch master cylinder
dave
#9 minimole
minimole
  • 781 posts
Posted 26 November 2005 - 08:43 PM
try another slave cylinder it is not uncommon to get new parts that are fualty.
#10 1984mini25
1984mini25
  • 8,784 posts
Posted 26 November 2005 - 08:53 PM
It was canged by last owner 9 months ago and done 3.5k since
By a rover dealer
Was replaced with a genuine rover short arm verto slave cylinder
Pedal feels fine but it grinds when u try to select gears especially reverse
didn't do this, this morning :lol:
Have tryed to re-blead 2night in the dark, still no joy :lol:
#11 binge
binge
  • 2,508 posts
Posted 27 November 2005 - 02:15 AM
I sorted mine the night it went shitty.
Was quite simple actually, And im proud of myself as Ive explored another part of my engine bay now! :lol:
Firstly I located the bleed nipple.
Then I filled the resivior up with Dot 4.
Then I got my lil sister to sit in the car, and push the pedal to the floor.
I then Undid the nipple and LOADS of fluld came pouring out.
She then pumped the pedal, And held it to the floor again. I undid the nipple again to release a load more fluid.
In the process of this, I also gave my master cylinder / slave cylinder a GOOD soaking in some "Handy Oil". And my clutch is really smooth now too. Feels like a new car...
So cheers for the help. Clutch is great noiw! :lol:
#12 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 27 November 2005 - 09:34 AM
lil sisters make excellent helpers when it comes to brake and clutch bleeding :lol:
Just in the process of training mine to do ball joints for me, she can already strip down an engine aswell :lol:
#13 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 27 November 2005 - 04:04 PM
dave
:cheese:
