hi im looking in getting some lowered shock mounts whats the difference between them and the normal type are they higher or lower (the mounting point)
whats the point in them really?
cheers
josh
Lowered Shock Mounts?
josh.evans
, Jul 24 2010 05:17 PM
8 replies to this topic
Posted 24 July 2010 - 05:17 PM
Posted 24 July 2010 - 06:51 PM
the shock mounting pin is higher so you can get your car nice and low with standard height shocks on, that way the shocks dont bottom out and you dont have to spend more money buying lowered shocks, hope this helps.. Lee
Posted 24 July 2010 - 09:10 PM
Josh you don't need lowered shock mounts as you have the shorter damper already
Try in the classifieds for a set of standard front shock brackets......
Posted 24 July 2010 - 10:44 PM
Im assuming your talking about the mounts available from reputable mini parts suppliers,not some cheap ebay fad?if so ,The point of using 'lowered' shock brackets is there designed to be used with shorter dampers and keep it upright(by having the mounting further in) as with standard brackets and lowered(shorter) dampers they end up tilting out at top mount,when they need to be kept upright to work properly.
So they dont 'lower' your car with standard dampers,they are 'required' when using lowered dampers.
hth
dave
hth
dave
Posted 24 July 2010 - 11:13 PM
THat is true, however Josh hasn't actually lowered his Mini, but the donuts are old and have sagged, so he has fitted the shorter dampers, not an ideal situation. But one that doesn't require the modified mounts.
Posted 24 July 2010 - 11:16 PM
thing is i have looked today at the amount of travel left on the shock and its only about a inch and a half??? would it be worth getting lowered type in this case?
cheers
cheers
Posted 24 July 2010 - 11:19 PM
Something not quite right here Josh, didn't you say the other day that you had a gap of about 3 fingers between the top of the wheel and the wheel arch ?
Posted 24 July 2010 - 11:20 PM
cheers
cheers
Posted 25 July 2010 - 09:51 PM
so... would i be ok to buy a pair of lowered mounts then as i need asap?
josh
josh
