Hello, I have acquired a Sanpet tacho. I was told it was previously used on a mini so have attempted to install it earlier to my vehicle.
The engine is a 1275 A+ with standard ignition components.
I have four wires coming out of the tacho, brown for earth, red for live a green which i assume is the feed from the positive side of the coil and a blue for the light.
So far i have connected to a good earth and taken a live feed from the fuse box, however the gauge is not working when the engine is running. Only the light seems to be working.
Have I got the wiring correct and can people confirm this can be used on an a series engine?
There is a switch on the back with two setting options. The picture with the paper in it is what was wrote on the back of the tacho before being repainted. Any clues what this indicates?
CraigyBoy
Tacho Wiring
CraigyBoy
, Jul 24 2010 06:25 PM
4 replies to this topic
Posted 24 July 2010 - 06:25 PM
Posted 24 July 2010 - 06:28 PM
tachos usually work from negative side of coil
Posted 24 July 2010 - 07:26 PM
mine has a live and a earth for the light and then a positive and a negitive to the coil and a ground for the actually tacho
Posted 27 July 2010 - 09:00 PM
anyone shed any more light regarding this tacho?
Posted 31 July 2010 - 08:35 AM
My one came with 4 wires & I fitted as followsanyone shed any more light regarding this tacho?
Red - Fuse box or switched +
Black - Earth
Green - White/Black wire behind clocks (or go to neg side of coil)
White - panel lights
